20 Most Recent
Panasonic PT-LB20NTU Multimedia Projector Questions & Answers
My Panasonic PT-LB20NTU Multimedia
Use the remote control and press the MENU button and select the OPTION with the UP and DOWN arrow buttons. Press ENTER button and then press UP and DOWN arrow button to select CONTROL PANEL use LEFT and RIGHT arrow button to VALID the control panel buttons
If you have a loss of the remote control while the control panel is invalidated.
Press and hold the MENU button for 2 seconds with pressing the ENTER button to enter the MENU and VALID the control panel.
1/25/2011 1:44:48 PM •
Panasonic...
Answered
on Jan 25, 2011
Our panasonic projector is swapping colors in
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
8/16/2010 1:58:41 PM •
Panasonic...
Answered
on Aug 16, 2010
PT-LB20VU unit won't power on
check for the following:-.
1--the power cord may be disconnected.
2--main power switch is turned off.
3---no voltage(electricity)in wall outlet.
4-the lamp cover has not securely closed.
5--check for blown power fuse and change it with the same rate.
6--defective power supply unit.---.
3/16/2008 6:30:26 PM •
Panasonic...
Answered
on Mar 16, 2008
Panasonic KX-MB2025 Toner Low Problem???
Does the machine say replace drum or toner. Two different units. If toner did refill or install a new toner. There is a chip on most drums and toner to tell the machine they are new. if you refill the toner the chip is still going to tell the machine it is used.
Panasonic DP-C266 does not print one color
If your Panasonic DP-C266 copier is not printing yellow and you have already attempted some troubleshooting steps, here are a few additional suggestions to consider:
- Verify Toner Cartridge: Confirm that the yellow toner cartridge is installed correctly. Ensure it is securely inserted into the copier and that any protective seals or tabs have been removed from the cartridge.
- Check Toner Levels: Check the toner levels of the yellow cartridge. If the toner is low or depleted, replace the cartridge with a new one. Even if the toner appears to be full, it's possible that the cartridge may be defective or experiencing a blockage.
- Clean Developer Unit: The developer unit may have accumulated debris or become contaminated, leading to poor toner transfer. Open the front cover and locate the developer unit. Carefully remove it and clean it according to the manufacturer's instructions. Use a soft, lint-free cloth to remove any toner or debris. Avoid touching the developer roller with bare hands.
- Check Drum Unit: The drum unit may be damaged or worn, resulting in the poor transfer of yellow toner. Inspect the drum unit for any signs of damage, scratches, or wear. If necessary, replace the drum unit with a new one.
- Perform Color Calibration: Use the copier's built-in color calibration feature to ensure accurate color reproduction. Refer to the user manual for instructions on how to access and perform color calibration. This process can help correct any color imbalances.
- Service or Professional Help: If the issue persists after trying the above steps, it may require professional assistance. Contact Panasonic customer support or schedule a service visit by a qualified technician. They have the specialized tools and knowledge to diagnose and address specific issues with your copier model.
When contacting customer support or a technician, provide them with detailed information about the problem, including the steps you have already taken for troubleshooting. This will help them in providing more accurate assistance and guidance tailored to your specific situation.
