20 Most Recent
Fuji FinePix AX650 16MP, 5X Optical Zoom Digital Camera Questions & Answers
Focus error finepix hs10
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping.
In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus.
The solution is to disassemble the camera and secure the screws.
These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered.
Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board.
Those who want to try the repair, follow the link to the service manual.
http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html
Milton Maenishi
I have a FinePix S1 and the display screen is not working. All other modes are working but no display
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
Lens will not retract. Powering up ok.
Pull and twist gently to see if that will dislodge whatever is keeping the lens from retracting. You may have gotten some dirt or sand in the mechanism. It doesn't take much to prevent retraction. If it is dirty, a little gentle action will sometimes free it.
