20 Most Recent Juki DDL-8700 Industrial Straight Stitch Sewing Machine, Servo Motor Questions & Answers
Why isn't my bobbin threading?
Georgia, Generally it is one of two problems: 1. there is a thread stuck in the spindle where the metal disk attaches to the machine. If this is the problem, put a couple drops of oil on the spot and pull the thread loose. While you are there, you should be able to see a tiny hole at the top of the metal where the spindle runs between the disk and the bobbin. Put a couple drops of oil in that also. 2. Somehow the whole bobbin mechanism has slid forward and is not coming in contact with your belt when you engage your bobbin winder. To fix that, unscrew the two screws that attach the WHOLE METAL MECHANISM to the table. Shove the mechanism back towards the back of the machine, SLIGHTLY, and retighten the screws. After this, you might want to check to make sure that the tension on your bobbin isn't too tight. You only need minimal tension on it to wind a good bobbin. Good Luck.
5/3/2016 11:33:54 AM • Juki DDL-8700... • Answered on May 03, 2016
Needle breaking
The most common problems that cause broken needles is a thread tension that is too tight and the machine needle/hook being out of time. ...
11/28/2015 4:13:17 AM • Juki DDL-8700... • Answered on Nov 28, 2015
2answers
Juki DDL-8700 wheel not turning. Initially running fine, after a few minutes, wheel seizes. Machine is oiled, and we can see oil in the viewing window, Machine looks very clean inside. Motor sounds
Have you tried cleaning it? Sometimes a piece of thread or some fuzz gets in between the parts and causes friction. If you have a manual, or can get one online, you should walk through the pages on cleaning and do each and every part of the cleaning. If that doesn't work, call a professional. There are service people who come out to your shop and work on industrial machines. Mine charges $55, plus parts if needed.
11/27/2014 12:48:35 PM • Juki DDL-8700... • Answered on Nov 27, 2014
How do I stop my Juki DDL-8700 machine from skipping stitches?
set up on quilting table? wheres the oil pan?? if your machine sews fine straight and skips on curves i think you are lifting the presser ft as you make the turn. theres nothing wrong with the machine. you could always change the needle which is always the first thing when you encounter a sewing problem.
10/8/2014 6:16:47 PM • Juki DDL-8700... • Answered on Oct 08, 2014
Knee lift won't engage on my Juki. Ddl-8700industrial straight stitch
tilt machine back and look at the lifter bar. try moving it now without any pressure on it. move ok then problem too much presser ft tension of the lifter plate on the vertical bar under the machine is bent or not high enough or not align with the botton of the part the machine thta connects to the presser ft. the lifter bar connected to the knee lifter can be bent to line up with the bar on the machine. go to the other side of the machine and look in thru the oil pan to see how they match up.
7/30/2014 9:04:38 PM • Juki DDL-8700... • Answered on Jul 30, 2014
I have a Juki8700 it does not seem to be feeding the fabric thru on the feed dog
ck presser foot tension. even with sightest presser ft tension goods should feed. next ck that your feeder plate is not loose or broken. take off the plate and see if u can move the feeders with your finger. tighten screws makinf sure the needle is centered inthe feeder plate hole. if this is not the problen then youe=r feeder plate teeth are too low or worn out. look up how to raise the feeders. the should be 1/8" above plate.
7/30/2014 8:36:33 PM • Juki DDL-8700... • Answered on Jul 30, 2014
My stiches are loose on the bottom of my banner - is it the bobbin or a tension issue?
If the threads on the back are loopy, you need to tighten the top tension. If you have a spare piece you may want to run some of the plastic through the machine until you get the tension correct. If the top tension is too loose, the stitching will just pull out.
7/16/2014 9:06:31 PM • Juki DDL-8700... • Answered on Jul 16, 2014
My juki 8700 h frays thread while trying to sew
Hello Daniel, I suggest you start with a new needle. Back off the needle thread tension and the bobbin thread tension to a minimum and see how it sews. If it does not ravel the thread, you can increase the tensions until you acquire the stitch you want.
3/27/2014 4:28:36 AM • Juki DDL-8700... • Answered on Mar 27, 2014
Hello, please give me the juki support link.
https://jukiamericas.com/pages/supportif you live in the USA or https://jukiindustrial.co.uk/support/ for the UK and Europe.
3/24/2024 12:14:48 PM • Juki Sewing... • Answered on Mar 24, 2024
3answers
I have a new juki DL 8700 and the fuse keeps blowing off. Initially, the machine ran for almost 3 hours until fuse blown off.
You should make sure it is grounded. Also, is it getting oil from the pan? Blown fuses usually mean there is an overload in the motor. Check that the belt is not too tight.
2/18/2024 8:57:59 AM • Juki Sewing... • Answered on Feb 18, 2024
I need the user manual of JUKI flora 5000 home sewing machine
Juki flora 5000 manual parts details
2/6/2024 4:03:20 AM • Juki Sewing... • Answered on Feb 06, 2024
How to thread a Juki DDW-122I
See Jiku Website. You can download the required manual by giving type of machine, model number etc. Juki-Manuals (jukilanka.com) There are more than 400 manuals on this site. You can find your required manual. Juki manuals
1/17/2024 3:10:18 PM • Juki Sewing... • Answered on Jan 17, 2024
Model SC-1-EB; error code E41545713
Sc1 error 26 code 1769160
12/16/2023 8:56:26 PM • Juki Sewing... • Answered on Dec 16, 2023
Juki HZLG210 sewing machine. Why does it cut thread while sewing?
I am not familiar with this particular machine, but I found references to the thread cutter. Did you try turning it off? Could the cotton thread be rotten, have you tried sewing with button thread? Thread Trimming Function correlates with the scissors icon on the face of the machine. The G210 in unique in the fact that it has this function, which will automatically trim the thread for you, leaving virtually no mess! This one is a life saver as it relives you from having to spend time cutting and cleaning loose threads! The text above was from here https://www.instructables.com/Juki-Sewing-Machine-1/ More here https://www.google.com/search?q=Juki+HZL+G210+trimming+thread+while+sewing ..
11/18/2023 11:56:37 PM • Juki Sewing... • Answered on Nov 18, 2023
Juki DDL-8700 Industrial Straight Stitch Sewing Machine, Servo Motor Logo
10 questions posted
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Juki Sewing Machines
Most Popular Question
tension loose underneath side tightened
  • Sewing Machines
