20 Most Recent Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL Questions & Answers
Need to download manual for irulu model# :x11
https://www.irulu.com/download-center-new
12/15/2017 3:22:08 AM • Irulu iulu 10.1... • Answered on Dec 15, 2017
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port. If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port. Also, some Cable adapters are On the Go wired, and may not work properly. It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
9/21/2016 11:01:19 PM • Irulu iulu 10.1... • Answered on Sep 21, 2016
Hi my name linda my husband bought me airulu 10 tablet. and it about 2,3 month I carked my tablet screen and can it be fix? are what,thank you
Yes. Any local phone repair shop like for can normally repair the screen. Parts plus Labour run about 110 to 150 usd
6/22/2016 4:10:55 PM • Irulu iulu 10.1... • Answered on Jun 22, 2016
How to uninstall apps
GO TO REMOVE APPS
5/13/2016 1:32:14 AM • Irulu iulu 10.1... • Answered on May 13, 2016
Tablet started but then shut off and now won't start at all.
Hi, my tablet Irulu 10.1 it is not working because said Unknown and No carrier, were are me do.
4/24/2016 3:27:04 AM • Irulu iulu 10.1... • Answered on Apr 24, 2016
IT IS NOT WORKING.sAYS ALL APPS HAVE STOPPED
Remove your battery for a few minutes . Then replace.
3/3/2016 2:03:37 AM • Irulu iulu 10.1... • Answered on Mar 03, 2016
Can't find camera flash on off
Irulu Tablet - Android Forums at AndroidCentral.com
forums.androidcentral.com/other-tablets/236406-irulu-tablet.html
Dec 18, 2012 - 24 posts - ‎21 authors Real 1G DDR3 Nand Flash 8GB Camera 0.3MPixels-Front Android ... Can't find apps as downloadable to such as ad card anywhere in google play. ..... Problem is, every time i reboot the tablet or the device is off then turned ... Irulu AX101 stuck on Irulu connecting my world, how ... 5 posts Sep 20, 2015 How do I change the camera view on an irulu tablet? 2 posts Apr 13, 2015 How do I keep my Irulu from turning on randomly? 2 posts Sep 30, 2014 Problems switching from front camera to back camera 25 posts May 13, 2014 More results from forums.androidcentral.com
How to find your Chinese Tablet firmwar
12/21/2015 7:17:02 PM • Irulu iulu 10.1... • Answered on Dec 21, 2015
How to an lock my tablet forgot passwort
Someone else asked the same question. I copied and pasted the answer to save it for myself. (This is _not_ my answer. I am quoting the technician who gave it, including her name). Note: This ''should'' work regardless of manufacturer. It is an ''Andriod'' thing. ---------------------------------------------------------- Andoid cell phone reset Here are the steps to perform a hard reset in your device: 1. Switch off the device. 2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode. 3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up. 4. When you see Android with triangle, then press together Volume Up + Volume Down. 5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation. 6. Choose option "Yes -- delete all user data" and accept with Power button. 7. Press Power button to select option "reboot system now". Best Regards, Katy Motorola Support
5/19/2015 3:18:24 AM • Irulu iulu 10.1... • Answered on May 19, 2015
How do i get my 10.1 inch irulu tablet to work?
you can calibrate your touch screen in Settings under Display Amazon com Customer Reviews iRulu 10 1 inch Android 4 0 Touchscreen Tablet...
4/13/2015 12:32:33 AM • Irulu iulu 10.1... • Answered on Apr 13, 2015
Having trouble trying to figure out how to do the touch screen calibration
Touch screen is not supposed to be "calibrated" by users. All my family uses touchscreen smartphones and computers and NEVER anyone mentioned the need of calibrating a touchscreen. If you have some problem with your touchscreen, it is something beyond standard devide operation and you should take it for service, if it is on warranty, to site where it should be serviced
4/12/2015 2:12:55 AM • Irulu iulu 10.1... • Answered on Apr 12, 2015
External keyboard not working
Did it ever work?
3/11/2015 4:02:22 AM • Irulu iulu 10.1... • Answered on Mar 11, 2015
Irulu iulu 10.1 inch Andoid 4.0 Touchcreen Tablet PC Support MID Google 3G WiFi Network & Bulit-in 1GB DDR3 8GB Nand Flash With RJ-45 Connector for Ethernet/ ADSL Logo
Popular Tags
85 questions posted
Top Irulu Tablets & eReaders Experts
 Mikey
Mikey
ADMIN Eric
ADMIN Eric
Paul Bade
Are you an Irulu Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Irulu Tablets & eReaders
Most Popular Question
connect irulu keyboard tablet besides
  • Tablets & eReaders
