20 Most Recent Toshiba 57H93 57" Rear Projection HDTV Questions & Answers
If the set when first turned on has noise lines or distortion (left to right usually) but after several minutes they diminish and go away you have a bad HYPER board.
If this is the case let me know and I will advise you on options.
Toshiba 57H93... | Answered on May 18, 2012
Please replace the battery with new one. If still problem replace the LED IR in your remote..
Regards, Jay
Toshiba 57H93... | Answered on Feb 22, 2011
I had the same problem and called sears they only chare $99 to come out free estimate. it was a circuit board had to be resoldered and it works great
Toshiba 57H93... | Answered on Dec 24, 2010
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
Toshiba 57H93... | Answered on Oct 07, 2010
your TV is having a power problem. I would suggest you visit A TECH to fix the fault for you because I don't think this is what you can handle.
Take care.
Toshiba 57H93... | Answered on Jun 02, 2010
your TV is having a power problem. Its receiving power but it cannot transfer the current to the necessary part because a capacitor, diode, etc but have been faulty. Until these bad components are replaced, the TV might not come on.
If you know about TV repairers, I would suggest that you open the TV and read the power part/panel with a meter, detect the bad component and replace it. Take note that TV stores a lot of current that can shock, so leave the TV for a while before you open it.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you.
I wish you good luck.
Toshiba 57H93... | Answered on May 25, 2010
these sets use a magnetic relay to turn on after a while the metal contact pads on the switch burn (just like turn signal flashers in a car)
this causes the relay to click closed but open up again before the TV can start. the relay is on the power supply board it should be labeled RL1 on the board, it is a small black or, brown plastic cube usually located next to the power cord. If all fuses are good this is the problem.
unsolder and, replace the relay.
Toshiba 57H93... | Answered on May 18, 2010
has a short in the power supply I suggest it is a technical revs
Toshiba 57H93... | Answered on Oct 27, 2009
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Toshiba 57H93... | Answered on Oct 20, 2009
after a power surge if you dont have in on a surge protector it probably fried the main board in the tv so it wont work anymore..woudl probably be cheaper to buy a new tv than to try to repair the one you have now
Toshiba 57H93... | Answered on Jun 09, 2009
hello yes there are fuses. the main one is located in the power supply it glass type it might be black where it has shorted if you replace it and it blows again then you have a dead short in the power supply good luck. ps on the main there are wickman fuses these are solder in to the board
shaun
Toshiba 57H93... | Answered on May 27, 2009
Protect screen Part # 23311038.......117.30
Fresnel screen ( inside ) # 23311014 ...65.47
Lenticular screen ( middle) # 23311128....81.96
You should only need the protector screen......T.
Toshiba 57H93... | Answered on Nov 29, 2007
Toshiba 57H93 57" Rear Projection HDTV Logo
Popular Tags
26 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
replace power supply
  • Televison & Video
