20 Most Recent
Toshiba 57H82 57" Rear Projection Television Questions & Answers
I can't switch the picture size.
defective hd cable box is possible but each unit has its own picture size adjustment. use your cable box remote and change size there. use tv remote to adjust tv size to auto. dvd the same thing
Toshiba 57H82 does not except commands from remote
Toshiba part # 23000852 remote receiver LED located behind
screen frame assembly.....Remove speaker grill...then remove
screen assembly....locate small PC board near RGB CRT's...
Replace soldered in part on board....re-assemble...........T.
Hdmi wont work
the hdmi is a hdcp circuitry meanining it handles high-bandwith digital content protection hence the hdcp its a security copy device that protects a device from intercepting digital data, this error code means its corrupted and needs to be reprogrammed digitally u will need an computer tech conversant with computer digital electronics
Color is washed out
57H82 does not have a color wheel but 3 picture tubes, remove rear cover and look for the three large black lens--if dusty they will lower brightness and make the set look dull or washed out.
Tv takes a long time to turn on.
I have a possible answer---are you getting noise lines across the screen for the first several minutes that would eventually clear up and give a picture or something else?
