20 Most Recent Toshiba 43H72 43" Rear Projection Television Questions & Answers
try to reset to factory settings...
Toshiba 43H72... | Answered on Aug 19, 2010
try factoring settings and then install again...
Toshiba 43H72... | Answered on Aug 18, 2010
use channel 0...10..20...
you must go in yhe meny and set convergens point to point...or use the auto function.....try to reset to factory first.....NOT REPLASE 220 RESISTOR..
You have a convergence issue. I can fix it. Let me know.
Toshiba 43H72... | Answered on Feb 10, 2010
how do i turn on my toshiba big screen tv red light blanks button want push in
Toshiba 43H72... | Answered on Dec 19, 2009
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
Toshiba 43H72... | Answered on Oct 18, 2009
Yes, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Toshiba 43H72... | Answered on Oct 04, 2009
try auto-adjusting the tv chanel
Toshiba 43H72... | Answered on Apr 21, 2009
THE CONVERGENCE DRIVER CHIPS NEED REPLACED. CHECKSUPPLY SAFETY RES ARE OK AFTER REPLACEING STKs RESET CONVERGENCE. CHANCE BOTH STKs.
Toshiba 43H72... | Answered on Sep 09, 2008
When was the unit repaired last? If it is doing the same thing and is only 5 years old, it sound like a bigger problem than just what was repaired. I own a 56" projection TV and mine is 6 years old and I have yet to have a problem with it...(I shouldn't have said that...) If I were you, I'd call Toshiba and explain the situation and that it has been repaired once already under warranty. Chances are, they'll be able to help you to your satisfaction. I once purchased a JVC stereo receiver from Circuit City and had to take it in to be repaired 5 times and the warranty had expired after my second trip up there, but they were nice enough to repair it - free of charge - the other 3 times. Toshiba seems to be a company that stands behind their product. Good luck! Hope this was helpful...
Toshiba 43H72... | Answered on Sep 08, 2008
You need to replace both convergence ICs they are STK392-110 you can get new replacements at the following link and they provide free instalation instructions with pictures so you can do the repair yourself in about a half an hour. You need to replace both ICs same numbers STK392-110. Heres the link.
http://servicemanuals.vstore.ca/
Toshiba 43H72... | Answered on May 26, 2008
This is a convergence problem. Try resoldering the pins on the convergence ICs. These are large black ICs attached to a heatsink. They should have about 15 pins and be marked STKxxx. If the resoldering does not resolve the problem, replace the ICs. These should cost about $15-$25 each.
Dan
Toshiba 43H72... | Answered on May 12, 2008
Toshiba 43H72 43" Rear Projection Television Logo
16 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
picture zig zag lines vertically
  • Televison & Video
