Hello jcside,
its not a costly repair the parts cost about $13.99 each (Convergence Amplifier ICs) Just remember you will need to change both of them. Also you will spend about $10 - $15 on the bias resistors.
Here is some advice I posted sometime ago, it applies in your case:
This denotes a convergence problem as you surmised. Believe it or not it would be cheaper for you to replace the two convergence amplifiers and the biasing resistors. You would not actually be replacing the convergence board since these devices are usually located on the deflection board in most cases. However in answer to your question, the boards are easily removed, depending on your level of patience (lots of cables to move around), I would also advise you to either mark down all of the connection you will remove, or take
pictures of the board and its connectors. If you choose to just replace the Amplifiers and the biasing resistors there is a lot of information on this site on how to do so: This will get you started:
1) Unplug the TV and then get a schematic of the
TV I use http://www.servicemanuals.net or http://www.manualsparadise.com
2) On the schematic locate the STK392-xxx series IC packs (usually attached to a large heat sink)
3) determine if the STK392s are 110, 120 or 150.
4) if the STK392-xxx's are 110s replace with 110s (forget that upgrade stuff it is a hit or miss
game that I don't believe you want to get into), if they are 120s replace with 120s and so on.
5)Now to replace the STKs: remove the module from the TV and unsolder theold STKs along with the bias resistors, and replace them with the newones (be sure to apply
heat sink paste to the STKs when attaching themto the
heatsink)
6) make sure there are no short circuits form your soldering job.
7) Reinstall the module and then turn on the TV.
8) do manual adjustment and the auto-convergence test and then things should be back to normal.
I hope this helps
Shuttle83
http://www.electron-age-technologies-llc.comNow if you think you can do this have at it, if not I would suggest that you have it done by a qualified TV technician.
