20 Most Recent
Toshiba TP55H60 55" Rear Projection Television Questions & Answers
Toshiba TP55H60 power down after start up
Try the following
1-unplug tv
2-remove bottom cover on tv
3-tap the power supply frame a few times (where the power cord enters the tv)
I had the blinking red light on my tv. I tried other solutions like removing the red wire a few times etc. Tapping the power supply frame solve the problem.
Toshiba 55inch rear projection.
Check your connections to make sure they are not loose, also if you pull the boards check for burnt solder points. I have parts that are good if you want them, very cheap. Email me at hill6399 at yahoo.
When turning on my panasonic cinemavision tv, it
Have you replaced or checked all the fuses? Do that first, then if you still are having problems, email me back. I will send you replacement parts, very cheap, and will tell you how to install. hill6399 at yahoo
My 55 Toshiba rear projection Will come on, then
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck.....
No display or audio
I had the same problem after replacing several things and still having same problem, it ended up being a capacitor.
I have a Toshiba Theater View and the power cord
hello if you take the back off look on the power supply board you should see a plastic whites clip with 2 pins coming off it or possible 3 just push it back in .
it will be at the top of the power supply board i hope it helps
regards
shaun
