20 Most Recent Element ELDFT501 50" LCD TV 1920x1080, 60 Hz, HDTV Questions & Answers
Does the main board for element tv control the picture
There are two board which controls the picture. The TCON board and the main board. If you wish to get some details about LCD TV repair then check the following link. http://electro-medical.blogspot.com/
7/24/2016 5:12:23 PM • Element ELDFT501... • Answered on Jul 24, 2016
Element tv with poor quality picture
You ordered the wrong part. Get the numbers off the Tcon board and replace that one
2/2/2016 8:20:34 PM • Element ELDFT501... • Answered on Feb 02, 2016
Universal Remote: Phillips SRP2024A/27 - looking for universal remote code for an Element ELEFT405. Thank you.
It is 2023, no one buys Universal Remotes! https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
New Replacement Remote Control Compatible with Element TV ...
Amazon.ca https://www.amazon.ca > Replacement-Compatible-EL... New Replacement Remote Control Compatible with Element TV ELEFC321 Elefj243 ... ELEFQ462 ELEFT405 ELEFC401 Elefj391 ELEFT195 Elefs : Amazon.ca: Electronics. $14.46 · ‎In stock
Replacement Remote Control for Element ELEFW248 ...
Amazon https://www.amazon.com > Replacement-ELEFW248-... Buy Replacement Remote Control for Element ELEFW248 ELEFQ402 ELEFQ462 ELEFT405 LCD LED HDTV TV: Electronics - Amazon.com ? FREE DELIVERY possible on ... US$26.99
Remote Control Codes For Element TVs
directutor.com https://www.directutor.com > content > remote-control... Remote Control Codes For Element TVs · 1687, 1886, 2183 · 3264 · 13559, 11687, 12964, 12260, 13907, · 11886, 11864, 12183, and 10178 · 11687, 11886, 12183, 12964, ...
Element TV codes for OneForAll universal remote controls
eliztech.com https://www.eliztech.com > remotes > codelists > eleme... Element TV codes for One for All remotes ; Smart Control 8 (URC7980) for OneForAll URC7980 remotes. 1687 ; Smart Control 8 US (URC7880) for URC7880 (US model). ..
8/26/2023 2:43:18 AM • Element... • Answered on Aug 26, 2023
2answers
How can I delete my fire stick remote that is connected to my TV and how can I add it on
To disconnect your Fire Stick remote from your TV, you can follow these steps:
1. On the home screen of your Fire Stick, go to "Settings" in the top menu bar.
2. Navigate to "Controllers & Bluetooth Devices" and select "Amazon Fire TV Remotes."
3. Select the remote you want to disconnect and then choose "Remove."
4. Follow the on-screen prompts to complete the removal process.
To reconnect your Fire Stick remote to your TV, you can follow these steps:
1. Turn on your TV and make sure that it is set to the correct input for the Fire Stick.
2. Press and hold the home button on your Fire Stick remote for at least five seconds.
3. Wait for the remote to pair with your Fire Stick. Once the pairing is complete, you should see a message on the TV screen confirming the connection.
If you want to disconnect and reconnect your Fire Stick to your Element TV, you can follow these steps:
1. Unplug the Fire Stick from your TV's HDMI port and power source.
2. Wait for a few seconds and then plug the Fire Stick back into the HDMI port and power source.
3. Turn on your TV and switch to the correct input for the Fire Stick.
4. Follow the on-screen prompts to complete the setup process.
Once the setup is complete, you should be able to use your Fire Stick and remote as normal.
6/20/2023 11:18:30 PM • Element... • Answered on Jun 20, 2023
I have an Element E4AA43R that is displaying vertical lines across the tv. Im not sure which board I need to replace to correct this problem.
Vertical lines across a TV screen can be caused by a variety of issues, including a faulty T-con board, a defective main board, or a problem with the display panel itself. Here are some steps you can take to troubleshoot the issue:
  1. Check the cables: Ensure that all cables are securely connected to the TV and the source device (such as a cable box, gaming console, or DVD player). Loose or damaged cables can cause issues with the display.
  2. Test the source device: Connect a different source device (such as a laptop or another TV) to the same input on the TV. If the lines persist, it's likely an issue with the TV itself.
  3. Check the T-con board: The T-con board (also known as the timing control board) controls the timing of the image on the screen. If this board is faulty, it can cause vertical lines. You can try replacing the T-con board to see if it resolves the issue.
  4. Check the main board: The main board controls the overall functioning of the TV. If it's faulty, it can cause issues with the display. You can try replacing the main board to see if it resolves the issue.
  5. Check the display panel: If the above steps don't resolve the issue, it's possible that there's a problem with the display panel itself. Unfortunately, this is the most expensive part of the TV to replace and may not be worth the cost.
It's important to note that diagnosing and repairing electronics can be dangerous and should only be attempted by a qualified professional. If you're not comfortable with troubleshooting or repairing the TV yourself, it's best to contact a licensed repair technician for assistance.
3/9/2023 7:32:49 AM • Element... • Answered on Mar 09, 2023
Element TV is flashing colors in random spots of the picture after being on for awhile. What could it be?
This will be a panel issue, don't waist money changing boards as they won't fix it. We've seen this hundreds of times in our shop, if you have a lot of spare time it can be fixed in most cases with a piece of tape, search tape fix for LED TVs on youtube to see how to do this, it actually works.
3/8/2023 12:05:56 AM • Element... • Answered on Mar 08, 2023
I have a Element 70" smart tv 2017 model E18115-XM
Element support. The manual should show if that model number is correct, but it doesn't. https://www.google.com/search?q=Element+E18115-XM+manual ..
2/26/2023 8:04:44 PM • Element... • Answered on Feb 26, 2023
I have an Element 55 inch TV. It is stuck in the standby mode meaning I can not turn it on. Any help would be nice.
Question edited for clarity. Why don't you just turn it on using the button on the side of the television? That will prove if the television is faulty or the remote is faulty. Nobody but nobody buys Universal remotes these days! No model given, so we guess :>D https://www.manualslib.com/manual/462372/Element-Eldft551.html?page=7#manual Remote Buying https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote ..
2/26/2023 7:37:08 PM • Element... • Answered on Feb 26, 2023
I have an Electrolux double oven and the fan motor has stopped working... I replaced the element and that is glowing orange and I have today replaced the fan...What can i try next please?
If you have replaced the fan motor and the heating element and the fan is still not working, there are a few things you can try next:
  1. Check the fan blade: Make sure that the fan blade is not damaged or obstructed. If the blade is damaged, it may not be able to turn properly and could cause the motor to fail again.
  2. Check the wiring: Check the wiring between the fan motor and the control board to ensure that it is properly connected and not damaged. Look for any frayed or broken wires that may need to be repaired or replaced.
  3. Check the control board: The problem could be with the control board, which may need to be replaced. Check the control board for any visible signs of damage or wear, such as burned or corroded contacts.
  4. Check the thermal fuse: The thermal fuse is a safety feature that can shut off the oven if it gets too hot. Check the thermal fuse for continuity using a multimeter. If it is blown, it will need to be replaced.
If none of these solutions work, it may be best to contact a professional appliance repair technician who can diagnose and fix the issue. They can ensure that the repair is done correctly and safely, and can help prevent further damage to the oven.
2/26/2023 11:37:58 AM • Element... • Answered on Feb 26, 2023
50 inch element tv no backlight. checked led strips, they seem to be working fine....whats next?
The next step would be to check the inverter board. This board is responsible for supplying the power to the backlight. If the inverter board is defective, it will need to be replaced. If the inverter board is not the issue, then the issue may be with the mainboard.
2/14/2023 5:38:31 PM • Element... • Answered on Feb 14, 2023
How can I display time on my older element tv ELPCFT421?
you cannot. this in older TV. here is a link to owners manual, copy and paste https://www.manualslib.com/manual/46218/Element-42-Pdp-Elpcft421.html#manual
2/3/2023 5:10:03 PM • Element... • Answered on Feb 03, 2023
Need a remote for element dvd player EDHft12.
If you find a generic replacement watch for buttons that may be missing from original
An original on ebay
Element EDHFT12 Remote Control Original Packaging w/ Instruction Manual And RCA
elpogoods (61)
100% positive feedback
$12.99Free shipping
or Best Offer
Est. delivery Wed, Jan 18 - Fri, Jan 20Estimate delivery
1/13/2023 4:24:13 AM • Element... • Answered on Jan 13, 2023
My element tv doesn't have a to put in it broke now is there any way where I can hook it up
No idea what your asking
11/20/2022 4:01:11 PM • Element... • Answered on Nov 20, 2022
2answers
My element tv screen say no media devices
Tongfang, or Element TV
You will need to select a sourse.
Your remote should allow you to choose a source .
Most will have an HDMI 1 and or HDMI 2 as well as TV for direct Co Ax cabling.
Once you’re connected to the correct one you should have a media connection
11/16/2022 9:33:42 PM • Element... • Answered on Nov 16, 2022
2answers
My element tv comes on but it shows no media device. What should I do?
How do I change it? None of the buttons on the remote move the cursor.
11/16/2022 9:33:39 PM • Element... • Answered on Nov 16, 2022
On an element 3211B when connecting an Xbox via hdmi my picture >s getting cut off around boarders. How to fix?
try going into set up and put on game
9/19/2022 5:07:02 AM • Element... • Answered on Sep 19, 2022
2answers
How do I connect my element to an antenna? I have used a satellite connection but cannot get some local channels I'd like.
Hi Norris, Check the TV user's guide and find out if your TV has a digital tuner because nowadays most over-the-air channels are digital. If your TV has a digital tuner then It would be able to decode the digital channels.
9/19/2022 5:05:52 AM • Element... • Answered on Sep 19, 2022
2answers
Element roku tv 50 inch screen not working after replacing all 9 LED backlights
Hi Kol, I would suggest checking all of the connections that you've disconnected to install the new LED strips. The LEDs are connected in series and it wouldn't make a difference if you installed them in a certain order. If after checking all the connections the TV still doesn't work then it might be a possibility that the new LEDs might be DOA. You can test the LEDs strips using a 9 volts battery and a couple of alligator clips. Test the LEDs one strip at a time. Hope this helps.
8/26/2022 11:52:15 PM • Element... • Answered on Aug 26, 2022
Element ELDFT501 50" LCD TV 1920x1080, 60 Hz, HDTV Logo
3 questions posted
Top Element Televison & Video Experts
matt martin
matt martin
Are you an Element Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Element Televison & Video
Most Popular Question
main board element tv control picture
  • Televison & Video
