20 Most Recent
Toshiba D-VR3 DVD Recorder/VCR Questions & Answers
CHANGE the REGION on my SONY DVD BDP-S185
From the users manual:
Region code (BD-ROM/DVD VIDEO only)
Your player has a region code printed on the
rear of the unit and will only play BD-ROMs/
DVD VIDEOs labeled with identical region
codes.
Nothing was said in the manual about changing the region code.
I have a Toshiba RDXV59DTKB
hi have a toshiba rdxv59dtkb cant finalize disc go to set up get dvd menu which is not hilighted like others in list
How can i connect my toshiba rdxv59dtkb2 to
be more specific please. Normally you could use A/V cables to your dvd recorder then from dvd recorder to TV.
from your signal that feeds to your tv just feed to the toshiba dvd recorder, then from dvd recorder to tv, then you should be golden. Just dont forget to set the channel on the dvd recorder.
Error message E 454039000 or E 454030206 or
I am not 100% sure on this one but it could be a problem with the clock if that DVD has a time display. Most of them try to get the actual time from the cable companies signal. Go to 'menu' and adjust/set the time manually. Disable auto time. Hope that works for you!
How to change region code on Toshiba D-VR3 player?
1) In DVD mode,press System Menu.
2) Go down to the Lock icon.
3) While lock is highlighed, press 0 for seven times (o,o,o,o,o,o,o).
4) There will be a pop-up window that asks you to confirm.
5) Press ok.
Jay
Multi-regional unlocking code
Below is the only known process to unlock your region settings. It is not 100% surefire but should work.
4) There will be a pop-up window that asks you confirm. Press ok.
Post back and let me know if this worked for you. Thank you for trying Fixya!
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
Toshiba 47" flatscreen. Power up
The information provided suggests that there might be an issue with the main board of the electronic device. However, it's important to consider a few factors before deciding to replace the main board:
- Check for Error Codes or Diagnostic Signals: Some devices have error codes or diagnostic signals that can provide more specific information about the issue. Check the device's manual or documentation for any error codes or signals associated with the flashing LED or other symptoms.
- Perform a Hard Reset: Before replacing any components, try performing a hard reset on the device. This involves turning off the power, unplugging the device, and waiting for a few minutes before plugging it back in and turning it on. Sometimes, this can resolve temporary glitches.
- Consult Manufacturer Support: Contact the manufacturer's customer support or refer to the product's support resources. They may be able to provide troubleshooting steps specific to your device and guide you on whether a main board replacement is necessary.
- Professional Inspection: If you are not familiar with electronic repairs, consider consulting a professional technician. They can inspect the device, run diagnostics, and provide a more accurate assessment of the issue.
- Check Warranty: If the device is still under warranty, replacing components yourself may void the warranty. Check the warranty terms and conditions before attempting any repairs.
- Consider Other Factors: The issue might not solely be with the main board. Power supply issues, faulty connectors, or other components could contribute to the problem. A thorough inspection can help identify the root cause.
If, after considering these factors, you still believe that the main board is the likely culprit and you are comfortable with the replacement process, you can proceed with replacing it. However, exercising caution and exploring all available troubleshooting options is advisable before making any decisions.
1/17/2024 8:35:42 PM •
Toshiba...
Answered
on Jan 17, 2024
