20 Most Recent Toshiba SDV395 DVD Player/VCR Questions & Answers
Buy a DVD cleaning kit and follow instructions, if no! the laser pickup assembly is bad, and not cost effective to repair
Toshiba SDV395... | Answered on Mar 16, 2012
Hello
There are two possibilities for this fault. The first one is of its loading belt. If loading belt, that fastened to loading gear wheel to loading motor get loose or broken, the tray won't come out or go inside. Just place your ear very near to the player, and push eject button and listen, whether there is a motor running sound for at least 3 seconds. If you hear this sound, make sure that the belt is brokenn. The second chance is with loading motor itself. If it do not get proper voltage or got dmaged, the fault you describe here will occur. To replace this motor, you have to disassemble the CD mechanism. You must have all the tools to do the work and experience to disassemble and reassemble the CD mechanism. The motor is not a costly part, and can be bought from most of the electronic spare part selling shops at your town. OK.
Toshiba SDV395... | Answered on Jan 18, 2012
You can change the Region Code of you DVD player but be aware that you have a limited number of changes, then the DVD player will be stuck to a certain region.
Search in the Options menu and change the region code to one printed on the french dvd case. To watch DVDs from your region again you have to change the region once more. Watch for changes left.
Toshiba SDV395... | Answered on Nov 02, 2010
Hi, you might have to turn the CC feature off from your TV and select the CC feature from the DVD disc set up.Refer to page 35 of the owners manual to get the correct language caption on your disc(dvd): basically press the audio key on your remote control until the desired captioning appears.
Toshiba SDV395... | Answered on Jun 21, 2010
For this unit the component output (green, blue, and red cables) only work for the DVD player portion of it. You will need to connect either the av input on the back or the front with composite (yellow, red, and white cables) to your television in addition to the component cables I assume you have connected already. Once you have done so you will need to switch this unit over to the right av output in order to access the vcr and also switch your television over to the right av input in order to pick up the signal from the vcr.
Toshiba SDV395... | Answered on May 05, 2010
This is a DVD player. It will not write to DVD but will play discs you have recorded elsewhere. You could (with non-copy protected discs) dub the DVD to VHS. To go the other way, you would need to connect the player to a computer with appropriate software or other DVD recording device.
I hope this helps.
Toshiba SDV395... | Answered on Mar 14, 2010
you dont need a code ust plug into the audio/video out put at the back of receiver that should work
Toshiba SDV395... | Answered on Oct 10, 2009
well it sounds like a problem with your lense. so just take it apart and look at your lens and see if there is anything wrong or out of the ordinary with it.
Toshiba SDV395... | Answered on Sep 27, 2009
perhap there is a menu button on the tv itself,then you need scroll through the menus
Toshiba SDV395... | Answered on Jul 28, 2008
can you still get into the menu?
Toshiba SDV395... | Answered on Jul 16, 2008
You may have to push the channel buttons on the source and check the video unit until you see whats playing on the main unit once you have a picture comming thru you should be able to record. if not let me know we can figure out some other solutions to get you up and recording.
Toshiba SDV395... | Answered on Dec 21, 2007
Use code search on your Westinghouse URC to find something that works. If a search through all codes stored in the URC fails, try a different one.
Toshiba... | Answered Yesterday
I may be guessing, but here goes. Make sure all the ink cartridges are seated. In Properties, got to Advance - have your settings checked off as follows: Spool print documents so program finishes printing faster, Aart printing after last page is spooled.
Clean the heads in printer, maybe a sllightly dirty cartridge opeining.
Other than above, I don't really know the correct solution.
Toshiba SDV395 DVD Player/VCR Logo
19 questions posted
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Televison & Video
Most Popular Question
dvd play works but vcr playing not
  • Televison & Video
