20 Most Recent
Dell Venue 8 Pro 32 GB Tablet Windows 8.1 Questions & Answers
How to bypass system password-administrator password dell venue 8 pro tablet
I will attempt to tackle your problem, however, I am uncertain if you need to bypass the bios password or the login password to windows operating system. Some hard drives also have passwords but from your question it seems to be one of the former 2. If it is a bios password or a windows login you can google Hiren's boot CD 15.2 restored v 1.1 DVD Proteus.ISO and follow the directions for creating a Bootable USB or burn it to DVD with any .ISO image burner like roxio or download image burn...it's free. At start up you may have to press esc or f-11 or f-12 to get the boot menu, choose the device that the boot CD is on by using the arrows on the keyboard, highlight the device and press enter, you will get the menu from the CD, depending on your issue , bios password you must go into dos mode, if login to windows you can enter either dos or mini windows xp or mini windows 7 and follow the instructions to remove or reset the passwords.Yes......give me your service tag number and I will generate the password for you, I have the factory service tag to password generator.....you have a bios password lock. If you also run into a windows password the horns CD will help you.
Why is my dell venue 8 tablet freezing
Most likely too many apps or a virus is attacking your device try using malwarebytes antimalware and avg free here are the links
Malwarebytes.org and free.avg.com
I cannot open my browser
Try restarting the tablet. If that fails to let you run a browser, you may have malware. You'll need to run a virus scan, preferably from an antivirus rescue CD like one from AVG or Avira.
Dell venue 3730 lockscreen bypass
Hardware Key Reset
If your device is not working because it is frozen then you wouldn't be able to reset it with the software. So the next option would be the hardware method.
1. Press and hold down the Power button + Volume down button + Camera button all at the same time until the device vibrates, now let go of the Power buttonwhile continuing to hold down the Volume down button and theCamera button.
2. Shortly you should see the message displaying "Are you sure you want to format?", you can now release the Volume down button + Camera button.
3. In the format screen you have the option to either Format or Cancel. Tap on Windows key Format if you are confident to go ahead.
4. Press on the Windows key again to confirm your choice.
Your device should now begin to format the device and shortly should startup with the Start-up Wizard. Ensure you device have the battery power while doing this
How do I hard factory reset dell venue8-3840 tablet
Your best bet is to google your specific device, but some have a small hole on the side and you can use a paper clip. Or power off, then power back on holding the power and volume down button down until a menu shows up on screen. You may have two or three options such as hard, soft, or recover reset.
