20 Most Recent
Toshiba 42HP83 42 in. HD-Ready Plasma Television Questions & Answers
Antsig remote codes
0937,0919,0993,0947 are the codes to check. If
you wish to get more details, check this site.
Pull up older posts there. Setup
code list and setup proceedings to many popular brand remote controls are
given. Two digit, three digit, four digit and five digit setup code list to
different models remote controls are given.
If you search the site in Timeslide option, which can be selected from
the drop down list at the top left of the display window, it will be easy to
locate the related post. You can also
do a search by type in the brand name and model number to your device into its
search box at the top right of display window. Check this link too.
http://electrohelponline.blogspot.com/
What does it mean when a red light flashing?
chances are a capacitor is blown on your psb.have a look for buldging
caps,its a plauge for these tvs.replace with like kind,very cheap to buy
from maplins and the like,will require soldering and basic skills
I have 42 inch toshiba, my husband cancelled our
The instructions are in your TV manual, but because of the complexity of the TV and it's features, it may be difficult to find. I believe it is on P. 31 (at least of the manual I got online). You'll need to connect a TV antenna appropriate for your area. If broadcast sites are close (line of site) a simple bookshelf antenna will work. With the antenna connected, and the antenna input selected in setup, you allow the TV to scan for local channels in your area. I hope this helps you.
No sound or pic, red
solution
step 1 : at first
test your fly back transformer
step 2 : A.C. transformer test
step 3 : test your TV tube just leak problem, I think
Send report :
[email protected]
I have a 42hp83 toshiba tv n when turned on i get
Check the connections to the TV, try to double check if the input source is good and does not carrry any video noise. the next thing would be a fault within possible with the drive, a screen failure or a processing fault..
