20 Most Recent
Samsung Galaxy Tab 3 SM-T210 8GB 7" 1.20GHz 1GB Android 4.1 Wi-Fi Tablet - WHITE Questions & Answers
Unable to switch on my samsung T210 tablet
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
Tablet problems with touch of the screen
let's start with the basics first in order to solve your tablet issue. Once we go that, we can move forward as necessary.
I would recommend performing an antivirus scan on your device. You can search for "avast" or "malwarbytes" in your app store to get started.
If that doesn't work, then you can perform a factory reset as described by Samsung here:
https://www.samsung.com/us/support/answer/ANS00062842/ . You'll be advised to back up your files before performing the factory reset.
Please let me know if this helped you or not.
