20 Most Recent
LG BL40 Chocolate Black Label Series Unlocked Phone GSM QuadBand with 5MP Camera WiFi and High Definition Touchscreen International Version with No Warranty (Black ) Questions & Answers
I NEED TO KNOW HOW TO UNLOCK MY VOICE MAIL CODE, CAN'T REMEMBER IT,CHOCOLATE LG TOUCHSCREEN?
Reset the Voice Mail Password from the Wireless Device
- Press *611 then press SEND (airtime is free).
- Listen to the instructions then when prompted, press 3.
- Listen to the instructions then when prompted say 'Reset voicemail password' or press 5.
- If prompted, enter the requested information for security verification.
- Follow the prompts to reset the password.
OR
- Call (800) 922-0204 (toll free) from any phone to reach the easy-to-use automated customer service menu.
Reset the Voice Mail Password Online
This method requires logging into My Verizon. To establish a profile, refer to
Register for My Verizon.
- Navigate: My Verizon > My Device >
- Create New Password
- Confirm New Password
- Click Submit.
Reset the Voice Mail Password for a Prepay Number
- Press *611.
- Press SEND (airtime free) to reach a service center.
5/11/2014 12:14:22 PM •
LG BL40...
Answered
on May 11, 2014
I cannot put a starhub sim card phone in a LG
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here
1/17/2011 6:55:08 AM •
LG BL40...
Answered
on Jan 17, 2011
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
How can I hatd factory hard reset my LG 265 if I don't have my pin # nomore or forgot it .
- Turn the phone off.
- Press and hold the Power/Lock key (on the right side of the phone) and the Down Volume key (on the left side of the phone) at the same time.
- When the Factory data reset screen appears, release both of the keys.
- Use the Volume keys to highlight Factory data reset, then press the Power/Lock key to confirm.
- Use the Volume keys to highlight Yes, then press the Power/Lock key to confirm one more time.
- Your phone will perform a factory reset.
Im locked out of my
WARNING : Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications.
- With the phone off, press and hold the Home key, Volume Down key and Power button. When the LG logo appears, release only the Power button.
- Release the Home key and Volume Down key when the Android icon appears.
- Follow the on-screen instructions.
Can an LG Stylo 4 with a cracked screen , showing only a black screen be repaired so i may extract data from it ?
It is possible to repair an LG Stylo 4 with a cracked screen that shows only a black screen to extract data from it. However, the success of the repair will depend on the extent of the damage to the screen and other internal components.
You can take your device to a professional phone repair shop and ask them to repair the screen. Once the screen is repaired, you should be able to access your data on the device. If the screen repair is not possible or too expensive, you may be able to extract data from the device by connecting it to a computer with a USB cable and using a data recovery software.
Note that data recovery software may not be able to recover all the data from the device, especially if the device has suffered significant damage. It's always a good idea to regularly back up your data to avoid losing important files in case of accidents or device failure.
