20 Most Recent
tmax White 8GB 9" Android 4.2 1.6 GHz, Dual Core, 1GB DDR Tablet WiFi, Dual Camera Questions & Answers
What size of sd card
Hi
Not sure by size, you mran phyical size or capacity. There are 2 phyical sizes.1) Standard SD card.2) Mirco SD card (usually used in phones) Check what size slot it is. I unsure take device to a retailer to check. If you mean data capacity size? These days most standard devices take from 32Mb upwards, check user manual or google device model specifications. The Extreme SD cards are a higher capacity. Check them out at a camera or retail store. Hope this helps. Regards Bob from OZ.
How to delete if internal memory card full
Hi
You can either download photo, data files to a SD card, another device (computer) or simply delete unwanted data by using the file brower. Locate, the unwanted files in storage, camera, or certain apps folders, & delete files. Don't delete any file in system folder. Hope this helps. Regards Bob from OZ
The android process in my smart eurostar tv. screen has stopped - how can i fix this problem
eurostar tv problem fix boot issue remove tv from power outlet hold down the power button and volume less button (negetive button) to boot make it boot in usb or auto reset from default software if it does not work then you need to download the correct motherboard firmware or software and format the usb fat32 and copy into it firmware files are avalable below my button did not work so removed firmware you need a telegram account can be downloaded from the link below https://gofile.io/d/M98jbz ( if this link not working then download from telegram account this is for eurostar 32 inch tv ) original link from telegram here https://dipelectronicslab.com/eurostar-t32sled-a14-update-software/ other webiste wheich helped me https://www.kazmielecom.com/ Try the key combination if inverted screen and colour https://www.youtube.com/watch?v=pZsGDgD6JQQ if the service mode does not come then use the command when the input selection menu is open and using the remote the following command menu 1147 menu 8896 menu 2580 source and 2580 source and 308(this worked for me it worked when i was after reset i selected inside tv then i open source menu in cvbs1) source and 208 search youtube if you are still not able to open there are videos where people show menu and number in source option 1) in the service menu if your screen a)if inverted screen issue go to panel settings LVDS mirror mode if on then off it (if off then on it) b)if clour is inverted LVDS map change it to next option (if vesa change to jeda) there is any other issue this both website hav tutorial for any other isssue
1/18/2024 5:25:00 PM •
Tablets &...
Answered
on Jan 18, 2024
How do I connect my PIXMA ip2820 to print from my google tablet
Methods that Setup Canon Pixma Ip2820 Printer Easily:-
1. Keep your Canon Pixma iP2820 printer on a place where you can handle it easily.
2. Insert the cartridges into the preferred slots.
3. Connect the power cable of the printer to complete the printer setup process.
If the Set-up does not work To
Setup Canon Pixma Ip2820 Printer, you want to join with Printer Error Support experts. You can also follow the easy steps to Setup Canon Pixma Ip2820 Printer are given below in the BLOG link.
12/18/2023 2:57:59 PM •
Tablets &...
Answered
on Dec 18, 2023
