20 Most Recent
Beko ECO WMB81445LW White 600 mm Washer Front Loading, 8kg, A Energy Rating Questions & Answers
Beko dishwasher drain din16210
The pipe or filter may be clogged. To check this, pour clean water through the drain. If it is clogged, use a plunger to drain the objects causing the blockage, if you are unable to successfully remove them, seek help from a plumber.
Why won't the washing machine start when I press the START/Pause/CANCEL BUTTON/
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Door switch if bad can be jumpered with a bypass, fisrt check with meter for ohms. Or open line cirrcuit this switch can hinder or stop operation, agitation or spin cycle.
Also check washer fuse usually located along the drum tub or inside control panel.
Some type washers may have a motor switch that my have been tripped.
Overheating
If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
Beko front loader washer dryer WDEX854044Q0G- Display keeps beeping and flashing through the wash settings.
If your Beko front loader washer dryer WDEX854044Q0G display keeps beeping and flashing through the wash settings, it could be due to a few possible causes. Here are some steps you can try to diagnose and fix the problem:
- Check for Error Codes: Your washer dryer may be displaying an error code that can help diagnose the problem. Check the user manual for instructions on how to access the error codes and what they mean.
- Check the Door: Make sure that the door is properly closed and latched, as this can cause the washer dryer to beep and flash. If the door is not closed correctly, the washer dryer may not operate.
- Check the Water Supply: Make sure that the water supply is turned on and that there is adequate water pressure. Low water pressure can cause the washer dryer to beep and flash.
- Check the Drain Hose: Make sure that the drain hose is not clogged or kinked, which can prevent the water from draining properly. Try removing any blockages or straightening any kinks in the hose.
- Check the Filter: The filter may be clogged with debris, which can prevent the washer dryer from operating correctly. Locate the filter on the bottom of the washer dryer and remove it to check for any blockages. Clean it out and reattach it.
- Check the Control Board: The control board is the brain of the washer dryer and controls all the functions. If it is faulty, it can cause the washer dryer to not operate correctly. Try resetting the control board or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the washer dryer thoroughly and ensure that it is working correctly and safely
Beko WMB81242LW stuck on spin cycle
If your Beko WMB81242LW washing machine is stuck on the spin cycle and won't change programs, here are a few things you can try:
- Check the door: Make sure the door is properly closed and latched, as this can sometimes cause the machine to get stuck in one cycle.
- Reset the machine: Unplug the machine from the power source for a few minutes and then plug it back in. This will reset the machine and may clear the issue.
- Check the control panel: Make sure the control panel buttons are working properly and not stuck in one position.
- Check the control board: The control board could be the cause of the issue, especially if your machine is 6 years old. A malfunctioning control board can prevent the machine from changing cycles.
If these steps don't work, it's best to have a professional repair the machine
Why do I get code EOO on Beko machine?
Error code EOO on a Beko washing machine usually indicates a problem with the drying sensor. Here are some steps you can take to troubleshoot and resolve the issue:
- Check the lint filter: A clogged or dirty lint filter can prevent the dryer from functioning properly. Clean the lint filter and try running the dryer again.
- Check the vent hose: A blocked or kinked vent hose can cause the dryer to overheat and trigger the EOO error code. Check the hose for any obstructions or damage and clear them if necessary.
- Check the moisture sensor: The moisture sensor detects the level of moisture in the clothes and adjusts the drying time accordingly. If it's faulty, the dryer may not be able to dry the clothes properly. Clean the sensor with a soft cloth and make sure it's not damaged.
- Check the heating element: If the heating element is faulty, the dryer won't be able to produce heat and dry the clothes. Use a multimeter to check the element for continuity and replace it if necessary.
If none of these steps resolve the issue, you may need to call a qualified technician to diagnose and repair the problem.
I forgot to replace lint filter. Within seconds something has disappeared and blocked what? Managed to fish a sock out but I can’t see or reach whatever else is there but it’s jammed I don’t what ????
If you accidentally forgot to replace the lint filter and something got sucked into the dryer, it's possible that the object got caught in the dryer's blower wheel or the vent hose. The blower wheel is located near the front of the dryer and pulls air into the dryer drum, while the vent hose carries the hot, moist air out of the dryer and into your home's venting system.
To access the blower wheel and vent hose, you'll need to disassemble the dryer cabinet. Before doing this, unplug the dryer from the power outlet to ensure your safety. Here are some general steps that may help:
- Remove the lint filter and unscrew the screws holding the filter housing to the top of the dryer.
- Use a putty knife or flathead screwdriver to release the spring clips holding the top of the dryer to the cabinet. Lift the top panel and rest it against the wall.
- Remove the screws holding the control panel to the cabinet, then lift the panel and tilt it forward to release it from the cabinet.
- Remove the screws holding the front panel to the cabinet, then lift the panel and tilt it forward to release it from the cabinet.
- You should now have access to the blower wheel and vent hose. Inspect the blower wheel and hose for any foreign objects that may be causing the blockage.
- Once you've located the object, you can use a pair of pliers or tongs to carefully remove it. Be sure to wear gloves to protect your hands.
- After the blockage has been cleared, reassemble the dryer in the reverse order that you took it apart.
Code EA on my beko washing machine? how to fix it
Beko washing machine error code e5
Error E5. This can mean a number of things but usually involves the machine not draining properly and taking too long to go through its cycle or not spinning. There could be blockages or problems with the pump/filter or an issue with the control board.
https://www.washingmachinerepairservices.co.uk/beko-washing-machine-error-codes/
