You can download dropbox from the Playstore. Setup an account, and you will get 50 gb extra because of the deal they have with Samsung. You will be able to sync your photos and videos from each of your Android devices, plus your computer.
Get the unlock code for Samsung galaxy s5 https://www.unlockninja.com/unlock-samsung+galaxy-s5Here is the steps to follow
-Select Purchase country-Select Locked NetworkApply to get the unlock code by update the IMEI
Type *#06# to know IMEI NO
) to unlockninja portaThe code will be delivered to your mail ID.
Here is the process to use the code
Just follow these simple steps to
Switch ON your Samsung Phone with a not Accepted SIM Card.
If the phone has had service for 12 months the carrier will unlock it for free. You do not need to unlock most phones if you are taking them to most prepaid carriers. Calm the carrier you plan on using before doing anything else.
Unfortunately it must have been a glitch in the software update which could've been caused by a virus \. The only way to fix the situation is by taking your phone to technician and let them remove the software you installed and they will delete the uploaded software and reinstall the original android firmware
Here is another way to unlock screen lock for Samsung Galaxy phones, works with pattern, password, fingerprint and Pin. no data loss
http://www.youtube.com/watch?v=lw4ueft-t_I
Insert a fingernail or plastic opening tool into the divot to the left of the rear-facing camera. Gently pry and twist the flexible rear cover off the back of the phone.
Insert a fingernail or plastic opening tool into the recess in the bottom right corner of the battery and lift upward. Remove the battery away from the phone.
Using a fingertip, pull the microSD card straight down out of its slot. Remove the microSD card from the phone.
To know more about disassembling procedure follow the link
http://electro-medical.blogspot.com/
call settings in settings
write down the current call diversions to voicemail settings in case you want to change it back !
Put in phone number put area codes in to the phone number.
But also be aware there may be call diversion charges each time call is diverted ! you may need to check with provider
Also be careful if your phone is in another country roaming could become very costly, you may need to check with provider
