might also be the it has to have its firmware re-flashed have tech come and check it out and have a good cleaning done. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Question edited for clarity, turned around, added CAPS, added the word 'manual'.Duplicate question should have been deleted but Kardoc has answered, albeit wrong model. Refresh page to see your question when you press 'Post Question'.UX-105 in Russian, or 510 in English, which is probably close enough.https://www.google.com/search?q=sharp+ux-105+manual..
Question edited for clarity.
Remove the curl out of the paper by running 6" across the edge of a desk against the curl. With scissors, cut the end 1/2" straight. Then cut a 1/2" off both corners at 45 degrees. Push the paper in the slot and press the Feed Button.
https://www.google.com/search?q=Sharp+EL-1197PIII.+How+to+load+paper
My instructions are better than the video, but shows the process well.
Just replace toner cartridge or refill the toner container with refillable sharp ar202 refill bottle or sachet. Remember to remove waste toner if you are refilling, right.
Check the Remote: Make sure you have the remote control for the projector.
Press the Menu Button: On the remote, press the "Menu" button.
Navigate to Security or System Lock: Use the arrow keys on the remote to navigate through the menu options. Look for a section related to "Security" or "System Lock."
Enter the Unlock Code: If you previously set a system lock code, you will need to enter it using the remote control. If you haven't set a code before, try the default code (often 0000 or 1234).
Disable System Lock: Once you've entered the correct code, navigate to the option to disable or unlock the system lock.
Confirm: Follow the on-screen instructions to confirm your choice, and the system lock should be disabled.
Reset the calculator: Locate the reset button on the bottom or in the battery compartment and press it .
Clean the printer head: Use a soft, dry cloth to clean the printer head and ensure that there is no debris or paper stuck in the printer mechanism .
you are looking for resources to properly align the gears. I found a few resources that might be helpful:
Sharp EL-1197PIII Operation Manual: This manual provides detailed instructions on how to operate and maintain your calculator, including how to align the gears. You can download the manual from the following link: SHARP EL-1197PIII OPERATION MANUAL Pdf Download ' ManualsLib.
Sharp EL-1197PIII User Manual: This manual also provides instructions on how to align the gears of your calculator. You can access the manual online from the following link: Sharp EL-1197PIII User Manual online (mans.io).
Sharp EL1197PIII Heavy Duty Color Printing Calculator User Manual: This manual provides instructions on how to align the gears of your calculator. You can download the manual from the following link: User Manual Sharp EL1197PIII Heavy Duty Color Printing Calc ' manualsFile.
Posibllities to eliminate: 1) bad door seal 2) unbalanced fridge on floor 3) buildup of ice in fridge (defrost) 4) faulty door alarm.
Check temp of fridge. Adjust up or down depending on whether too hot or too cold. Check for blocked air flow or too many items in freezer. But if the exterior is much warmer than usual, you may be looking for a repairman. The main circuit board might be blown
Try a reset by unplugging it for 5 minutes, then plugging it back in. If a minor problem, this may stop the beeping.
Maybe worth a look through this catalogue but I doubt spares are available;
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&ved=2ahUKEwjizJ7-k92DAxWzQkEAHUqwDmQ4ChAWegQIBxAB&url=https%3A%2F%2Fwww.specialized.net%2Fmedia%2Fwysiwyg%2FSpecialized%2Fetc%2FSpring-2023-catalog.pdf&usg=AOvVaw2Z06h4GZtS13wC9OK0rLZl&opi=89978449
Here is the manual link
Press CTRL+F Type in 'tax' top right, press Enter. Scroll through the 19 mentions, Number 3 shows it. Copied and pasted below, but it doesn't show symbol image. The first paragraph covers getting into setting mode and setting date and time, then comes 'Tax Rate'.
https://www.manuallib.com/download//SHARP-EL-1801PIII-OPERATION-MANUAL.PDF
GT • RATE SET GRAND TOTAL / RATE SETTING MODE SELECTOR: "GT": Grand Total "•": Neutral "RATE SET": To set the date, time, and tax rate, set this switch at the "RATE SET" position. Date: • Enter in the order of month, day and year, then press to complete the entry. • Use to separate month, day, and year. • When is pressed, the number entered is evaluated and displayed as "date" if the value is within the following range; "Error" is displayed otherwise, and the previously set date is restored. Month: 1 - 12; day: 1 - 31; Year: 2000 - 2099 (in 4 digits) or 00 - 99 (in 2 digits) Time: • Enter in the order of hour, minutes, then press to complete the entry. (There is no entry available for the seconds value. The clock starts at zero second.) • If the hour/minute digit is less than 10, it is not necessary to enter the first digit "0". • Use to separate hour and minute values. • When is pressed, the number entered is evaluated and displayed as "time" if the value is within the following range; "Error" is displayed otherwise, and the previously set time is restored. Hour: 0 - 23 (24-hour system for the hour entry), Minute: 0 - 59
Tax rate: • Press three times, enter the tax rate, followed by . • A maximum of 4 digits can be stored (decimal point is not counted as a digit). • Only one rate can be stored. If you enter a new rate, the previous rate will be cleared.
more here and videos
https://www.google.com/search?q=sharp+el-1801piii+set+tax+rate
