20 Most Recent Ricoh Aficio SP 9100DN Laser Printer Monochrome - 75 ppm Mono - USB - Fast Ethernet - Mac, PC Questions & Answers
I had the same problem, but solved it.
You have to connect your printer SP210 to your computer.
Search (in Windows) "Smart Organising Monitor Status"
Select Printer (new dialog box)
Click OK (see the error code SC545)
Click on User Tools
Printer Configuration
(Access Code is Admin074)
Find Fuser SC Reset under Maintanance
Click Ok
Close
Restart your printer
Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer
Press C (Red colour centre) button once
Enter 107 (nothing will be shown)
Press the Green (Coping) button for 5 seconds
See the Display -->
Select Engine Maintenance
Select Ok
Select Fuse SC Reset (press down arrow - at down you will find it)
Execute (by Pressing the Down Arrow)
Done
Restart your printer.
Your problem should be solved....
Ricoh Aficio... | Answered on Aug 20, 2019
Check its connected to a network, the DHCP server is probably your router if you have a small or home network.
see
http://www.fixya.com/support/t25283562-solve_cannot_connect_dhcp_server_101#solution-section
Ricoh Aficio... | Answered on Jun 29, 2019
Probably, you will have to call your local Ricoh servicer for repair.
Ricoh Aficio... | Answered on Jun 27, 2019
SC 899 is a software error. For example printing from directly from a website. Various printing from websites makes 899 error. Just remove the print queue from the computer and that's it. Make sure you save the file first from the website before you print to avoid same problem.
Ricoh Aficio... | Answered on Jun 03, 2019
Replace Charge corona end blocks
Ricoh Aficio... | Answered on Apr 29, 2019
You need to replace the HDD. It is very simple. Then format it in SP Mode. Reboot. Ready to use.
Ricoh Aficio... | Answered on Apr 25, 2019
Software error 3: Undefined An error not controlled by the system occurred (the error does not come under any other SC code
Ricoh Aficio... | Answered on Apr 17, 2019
  • Toner Collection Unit Lock The toner collection coil rotation sensor did not detect rotation of the coil within 5 s after the drum motor
Polygon Motor Error 1: ON Timeout The polygon mirror motor did not reach its operating speed within 20 s after the polygon motor
Memory error. The machine detects a discrepancy in the write/read data during its write/read test (done at power off/on and at recovery
Ricoh Aficio SP 9100DN Laser Printer Monochrome - 75 ppm Mono - USB - Fast Ethernet - Mac, PC Logo
1 questions posted
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Aficio Ricoh
  • Aficio Ricoh
Most Popular Question
spc440dn not print service mode 1103
  • Office Equipment & Supplies
