20 Most Recent Sony BDP-S1200 Blu-ray Disc Player - 1080p Dolby TrueHD, DTS HD, Dolby Digital, DTS, DTS-HD Master Audio - BD-RE, DVDRW, DVD-RW, CD-RW - NTSC - BD Video, DVD Video, MPEG-2, BDMV, XviD, MJPEG, MOV, AVI, VC-1, M2TS, MTS, ... - Progressive Scan - Ethernet Questions & Answers
are you sure the player will do blu ray disks
Sony BDP-S1200... | Answered on Feb 04, 2015
No! Sony has kindly locked there BDP range of BluRay players to the region country they were made for only and not multi region.
Sony BDP-S1200... | Answered on Jan 19, 2015
Have you been playing cd etc from different countries. The cd units in this country will lock you out after about three tries, that is the law.
That is because it is a DVD controller, not a TV controller.
Sony Televison &... | Answered Yesterday
You will find it if you google it.
Sony Televison &... | Answered on Dec 01, 2019
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter.
2 red flashes is bad power board, solution replace power board or repair it.
Possibly tv reach its end. Save money and replace it with modern energy efficient tv.
Unless your Sony remote control is programmable, you are unlikely to be able to find a code for your Sansui TV.
Sony Televison &... | Answered on Nov 27, 2019
Use code search on your GE URC to find something that works. If a search through all codes contained in the URC fails, try a different one.
Hi Daya,
It is a panel fault. It can be repaired. But it is a tricky and risky job. To attempt this repair you need to be an experienced technician. If you are a technician, please let me know. I will give you the details.
Sony Televison &... | Answered on Nov 23, 2019
Whats the model of the TV?
Thanks
Or something is overheating You can try updateing your software. But if that doesnt work I would take it to a repair shop.
Sony Televison &... | Answered on Nov 21, 2019
In most cases, the issue might be with the Java contents on the new Blu-ray discs is making this issues. The Blu-ray technology is developing everyday and adding more and more features to the existing technology. Hence it is required to make the Blu-ray Player up-to-date by installing the latest firmware update available from the manufacturer (who ever it is). Going ahead with the first step, please install the latest firmware update available for the Blu-ray Player.
Please click the following link to get the latest firmware update available for your Blu-ray Player:
You can enter the model # of your Blu-ray Player to download the firmware update for your player.
http://esupport.sony.com/US/perl/select-system.pl?DIRECTOR=DRIVER
You can review the "Important Notes" and "Firmware Update Instructions" on the page to get the instructions to install the firmware update.
If the issue persists after installing the firmware update, the would have been with the disc. Check the disc with another player, try different discs with same player.
If the Blu-ray Player is not at all playing any Blu-ray disc, then it may require service.
Sony Televison &... | Answered on Nov 13, 2019
Sony BDP-S1200 Blu-ray Disc Player - 1080p Dolby TrueHD, DTS HD, Dolby Digital, DTS, DTS-HD Master Audio - BD-RE, DVDRW, DVD-RW, CD-RW - NTSC - BD Video, DVD Video, MPEG-2, BDMV, XviD, MJPEG, MOV, AVI, VC-1, M2TS, MTS, ... - Progressive Scan - Ethernet Logo
3 questions posted
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
wen use disk bleu ray image jump don t
  • Televison & Video
