20 Most Recent Samsung RF267AB (25.5 cu. ft.) Refrigerator Questions & Answers
We had a breaker go off and when I reset it the
Take a look at this link .. should be a Samsung pdf file. It at least indicates to clear the two "88"s on either side ... to press simultaneously the "energy savor" and "alarm/lighting" buttons. Then an error code may come up ... and look at the chart of codes to see what the issue is https://www.pcrichard.com/images/promos/RF267AB-AC%20Fast%20track%20R1.pdf Good luck on your troubleshooting
1/17/2018 2:29:00 AM • Samsung RF267AB... • Answered on Jan 17, 2018
How to replace water filter Housing?
most of the time when you get a filter it has its own housing and they are and in the water line filter, just unscrew the water line and replace, just make sure the arrow is going in the right direction
12/3/2015 2:24:33 AM • Samsung RF267AB... • Answered on Dec 03, 2015
Water leaking at bottom of fridge
Freezer /fridge water/ice in fridge and or freezer Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out. Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor. However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also. Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then
4/10/2015 6:31:11 AM • Samsung RF267AB... • Answered on Apr 10, 2015
2answers
Water is pooling under vegetable/deli
Its a defrost problem.Click this link below and follow the troubleshooting:--- http://technoanswers.blogspot.com/2011/07/water-is-pooling-under-vegetabledeli.html ---------- This should help.Thanks.Helpmech.
4/5/2015 9:46:37 PM • Samsung RF267AB... • Answered on Apr 05, 2015
Refrigerator and freezer not cooling...Fans running coils clean
freon level? is compressor running? check out therrmistors also
3/13/2015 12:19:09 AM • Samsung RF267AB... • Answered on Mar 13, 2015
How do I defrost my Samsung rf267 refrigerator
All else fails unplug it for a couple hours. Don't forget your food will spoil though turning off the unit.
1/10/2015 12:01:20 PM • Samsung RF267AB... • Answered on Jan 10, 2015
0answers
I have a Samsung RF268ABRS
I had a similar problem. my samsung freezer would only cool to 20 degrees, which also resulted in the freezer ice maker not functioning. (fridge door ice maker still worked) If you hold the power freeze and power cool buttons down together for 8 seconds it will a diagnostic. found the answers on http://appliancejunk.com/forums/index.php?topic=8206.0 , as too what the codes meant. Mine was throwing a freezer fan code error. ordered one online $30 and replaced it. seems to be working. TIP -The fan is located behing the rear panel in the freezer. I had two fans. The regular looking one is the freezer fan, the squirrel cage fan feeds the fridge ice maker. Also the new fan motors don't come with blades, just pull the blades off the old one and put it on the new motor. Don't push it on too far, make sure there is enough clearance so it spins freely.
8/8/2013 8:25:01 PM • Samsung RF267AB... • Answered on Aug 08, 2013
I need a manual for my refrigerator
You can print it out by clicking on this link. Hope this helps you!
http://www.ajmadison.com/ajmadison/itemdocs/20080310100052218_DA68-01739A_EN_02.pdf
9/14/2011 7:46:00 PM • Samsung RF267AB... • Answered on Sep 14, 2011
Have frost in freezer compartment.
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/11/2011 7:17:35 PM • Samsung RF267AB... • Answered on Sep 11, 2011
WILL NOT MAKE ICE AND WATER RUNS OUT SLOW
NOTE: This
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
8/10/2011 4:36:49 PM • Samsung RF267AB... • Answered on Aug 10, 2011
No water is coming from
NOTE: This
If its leaking same part needs replaced.The water valve at the bottom rear of fridge
Leo Ponder
imufo2
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
8/2/2011 1:27:13 AM • Samsung RF267AB... • Answered on Aug 02, 2011
2answers
Hi. We had a power outage and now the control
Hi and welcome to FixYa, I am Kelly,
Press power cool and power freeze at the same time for 8 seconds.. The control panel should reset. If pressing pwr cool and pwr freeze shuts off the compressor it can be 10 mins of more before it restarts. If it does not reset... respond here and I will dig through the service manual and get back to you.
Kelly
7/20/2011 3:22:32 PM • Samsung RF267AB... • Answered on Jul 20, 2011
I am an independent appliance tech. i replaced a
• Is the water tank frozen because the Refrigerator temperature is too low? Try selecting a warmer setting on the main display panel. If the tank is getting cracked due to over freezing then either the temperature is set very high cooling or the defrost is not working properly, get the defrost checked.If too much ice gets collected in the freezer section, the internal parts gets over cooled and this cause freezing to some parts and they gets cracked.Other wise this eater tank parts are quite strong to function and work properly as well as last long.-------- --------- Also click this link and check the tank wiring diagram:--- http://downloadcenter.samsung.com/content/UM/200907/20090726134517125/DA68-01819A-EN.pdf ----------- The wiring diagram on page number 37. Check the water tank heater wire.May be that heater wire is got loose and due to that water tank got over cooled and this cracked the tank.------ --------- This will help.Thanks.Helpmech.
7/6/2011 9:31:47 PM • Samsung RF267AB... • Answered on Jul 06, 2011
Samsung RF267AB (25.5 cu. ft.) Refrigerator Logo
55 questions posted
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Refrigerators
Most Popular Question
need manual refrigerator
  • Refrigerators
