If a screen appears, and picture is absent, the fault is with its main board. If scree too do not appears, the fault is with its back-light circuit. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Timeslide" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".http://electronicshelponline.blogspot.com/
It sounds like there may be an issue with the power supply or internal components of your Proscan PLDED5030A-RK TV. The blinking blue light and popping sound could indicate a malfunction that is preventing the TV from turning on properly.
Here are a few steps you can try to troubleshoot the issue:
1. Unplug the TV from the power outlet and leave it unplugged for at least 10-15 minutes. This can help reset the internal components of the TV.
2. Check the power cord and connections to ensure they are secure and not damaged. If there are any visible signs of damage, such as frayed wires, replace the power cord.
3. Try plugging the TV into a different power outlet to see if the issue persists. This can help determine if the problem is with the power source.
4. If the issue continues, it may be necessary to contact a professional technician or the manufacturer for further assistance. They can diagnose the problem and recommend the appropriate repairs.
It's important to exercise caution when dealing with electronic devices, especially when there are signs of malfunction such as unusual sounds or lights. If you are unsure or uncomfortable with troubleshooting the issue yourself, it's best to seek help from a qualified professional.
If it is a copy remote for the Proscan Model you have, it should work when you insert the batteries.
If it is a Universal Remote, you need to put the Proscan Code into it.
The Proscan PLED5544U is a 55-inch LED TV. While it doesn't have a physical reset button, there are a few ways you can reset it:
Unplug the TV: Unplugging the TV from the power outlet for a few minutes can help reset it. This allows any residual power to dissipate and can clear any minor software glitches.
Use the remote control: Press and hold the power button on the remote control for at least 10 seconds. This can sometimes reset the TV.
Use the menu: If you can access the TV's menu, you can try resetting it through the settings. Go to the "Settings" menu, then "System" or "General" settings. Look for an option to reset the TV to its factory settings.
If none of these steps work or if you're experiencing other issues with your TV, it may be best to contact the manufacturer or a qualified technician for assistance.
If your Proscan tablet and DVD combo is locked, you can try the following steps to unlock it:
Restart the device: This is the simplest and quickest solution. Simply restart the device by holding down the power button until it shuts off, then turn it back on.
Check the lock button: Some devices have a lock button that can be used to lock and unlock the device. If your Proscan tablet has a lock button, check to see if it's in the locked position and adjust it if necessary.
Reset the device to factory settings: If restarting the device and checking the lock button don't work, you can try resetting the device to its factory settings. This will erase all data and settings on the device and restore it to its original state. To reset the device, you may need to access the settings menu and look for an option to reset the device or perform a factory reset.
Contact the manufacturer: If you're unable to unlock the device using the steps above, you may need to contact the manufacturer for further assistance. They should be able to provide you with more specific instructions on how to unlock your device, or if necessary, repair or replace it.
I hope this helps! Let me know if you need anything else.
The model doesn't exist. All question need
'make model (what it is)', first 3 words and in that order.
"channel button". is it a television? Reset would be in Settings / General. You have the Remote? All sets need a Remote.
https://www.google.com/search?q=proscan+3373a
They make a lot of stuff!
Proscan Video - TVs, tablets, DVDs, and camerashttps://www.proscanvideo.comProscan manufactures and distributes quality electronics & appliances such as Televisions, Tablets, DVD systems, portable and home stereos, and cameras.Contact Us · Television · About Us · Manuals & Downloads
Proscan Tablet reset, Standard Android Hard Reset.
1) Go the Sound Tab on the remote's Proscan menu
2) Set the system's "Digital Audio Output" to PCM (pulse code modulation)
3) Connect a coaxial cable from the Coaxial "jack" on the back of the TV to the Digital Input "jack" on the back of the sound bar.
It should work now!
ManualsLib has the manual for the Proscan PLDED3996A-E here: https://www.manualslib.com/manual/1501801/Proscan-Plded3996a-E.html . See page 6, https://www.manualslib.com/manual/1501801/Proscan-Plded3996a-E.html?page=9#manual , for the locations of the control buttons on the back of the TV. The buttons are in the lower right-hand corner, as you face the LCD panel; thus they are on the left if you look at the back of the TV. The menu button is the third from the bottom in the stack. The volume buttons are at the top. The Standby (power) button is the lowest button.
I hope this helps.
