20 Most Recent Trio Mach Speed Stealth G2 Tablet - Teal in Color- 7" Dual Core Android 4.0 Internet Tablet with Google Play Store Questions & Answers
2answers
Get my tablet to get off the @9dualcore screen?
Have you tried the reset method below? There's a hard reset process on the G2 7" that I have used successfully on several stuck units. It may also I've learned work on other models of Trio tablets and other Android-based brands / models as well. It did on a Zeki 7" 8GB that I owned as well. But.... TRY AT YOUR OWN RISK. Here it is. (1) PRESS AND HOLD the power button until the tablet shuts off completely. (NOTE: if any type of start-up screen comes on, FORGET it: the Tablet must be COMPLETELY powered off for this to have any chance of working.) (2) PRESS AND HOLD the volume-down button, while simultaneously PRESSING AND HOLDING the power button This will (hopefully) bring up the Android figurine, along with some kind of rotating-wheel graphic. (3) Do nothing else but WAIT, until the screen changes to a text-based menu, with about 6 to 8, or more choices. (4) Use the volume-up and volume-down buttons to navigate between choices, and select (highlight) the choice offering to reset the tablet (to Factory Settings). (5) Click and release the power button to start the reset operation. Follow and additional prompts to ensure you are selecting the correct next step. This RESET process will erase ALL your installed apps, as well as delete all your saved photos, music and other user files and preferences (including wallpaper, time-zones, Wi-Fi settings etc. But when it works it will give you back a working Trio. Use your reset Triot carefully: generally, I'll say the Trio machines are good economical alternatives to the perhaps more robustly engineered (and much more expensive) big brand items. Regarding restoring personal preferences, and earlier installed apps I have no experience whatsoever. However there may be sufficient arguments to backup your personal data either on your home computer or on online "cloud based" services. Do the research, ok? Happy New Year, 2015 ... & ....Good Luck!
7/8/2018 7:45:25 PM • Trio Mach Speed... • Answered on Jul 08, 2018
I have the Trio 7" Dual core tablet. The battery is not charging completely, can this battery be replaced and if so where do I find the battery in the unit?
Battery replacement is possible. The battery is a flat component encased in a shiny silvery sheath behind the speaker area inside the back cover. It's mounted with double-sided (very) sticky-tape. A replacemnent battery should be sourced, having the same power specifications as well as physical dimensions. (see detailed close-up photo attached.) Replacement involves desoldering the 2 terminal wires (1 red and 1 black) which attach it to the main board, and replacing the battery with a new(er) unit. The above having been said,I'd only replace the tablet battery if I was sure that it's the battery at fault. Here's what I'd suggest. First, check that you're using a charger with the proper 5 Volt / 2Amp (2000milliamp) output. Also I'd suggest you use a charger designed to be plugged intothe G2 7" Dual-Core tablet's dedicated charging port. (See sample tablet charger in attached photo) The G2 tablets WILL typically accept charging output via the micro USB port, for example, from a typical cell phone charger. However typical phone chargers which will happily attach to the Trio or other similar tablets, via the micro-USB port do NOT often have the same output power specifications. This I think may cause difficulty with the tablet battery not reaching the fully-charged status. Also, the use of the USB port for charging may cause access problems if the battery power is low during some operations (eg data transfer in slave mode), as the charging port can not multitask as the USB port can. If power to the main boad is lost during such operations the tablet may become "bricked". Bottom line for me would be to use the dedicated appropriately rated charger whenever possible: it's the reccommended charging method. 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-3.jpg 25239131-kxzyo1nfvoux0zgzt1u5dqab-5-5.jpg
1/10/2015 2:47:53 AM • Trio Mach Speed... • Answered on Jan 10, 2015
2answers
How to install rom on Onn 100011886 tablet go edition.
"rom"? What exactly are you trying to do? Are you referring to ROM as part of the tablet's memory? If yes, you probably will not be able to do it. ROM is a memory chip built onto the circuit board itself inside the tablet. You would need to completely dismantle the tablet to do it. Most tablets are not built to be taken apart for repairs.
4/13/2024 11:56:23 PM • Tablets &... • Answered on Apr 13, 2024
2answers
Naxa NID-1070 2-in-1 Core Android 11 Tablet. My mom doesn't remember password for screen how to unlock.
Question edited for clarity, add maker. Not a good idea posting your email address as a user name!! This site get 11 million viewers a year including thousands looking for addresses to harvest and spam. We don't email answers, it is all done on the site. You have to turn it off and then hold the buttons. https://www.google.com/search?q=naxa+Nid1070+tablet+reset ..
4/4/2024 7:44:14 PM • Tablets &... • Answered on Apr 04, 2024
Straight wire charger to jp5 tablet
It is a non-proprietary see through charger as seen here https://www.google.com/search?q=jp5+tablet+charger ..
3/31/2024 5:51:01 PM • Tablets &... • Answered on Mar 31, 2024
2answers
How to get iPad unlock when you forgot your password?
If a power cycle does not resolve your issue, you may need to perform a hard reset. To do so press and hold the Sleep/Wake button and Home button until the Apple logo will appear and iPad will reset. You can also perform a factory device reset.
Apple iPad 4th Gen (2020) - Reset Device - AT&T
How to Hard Reset or Restart an iPad (All Models)
Lifewire https://www.lifewire.com > Apple > iPad Oct 19, 2023 - For iPads without Home Buttons: Quickly press volume down, then quickly press volume up, then press and hold the on/off button. Skip to step 3. ..
3/23/2024 11:24:03 PM • Tablets &... • Answered on Mar 23, 2024
How do I start my ONN tablet please?
Press the On button on the ONN tablet :>D https://www.google.com/search?q=start+my+ONN+tablet ..
3/7/2024 8:27:51 PM • Tablets &... • Answered on Mar 07, 2024
ProScan Elite tablet/DVD Player. Why won't it connect to WiFi?
Sorry to say, but Proscan are cheap Chinese junk that costs $60. If your WiFi is STRONG, and you are close to it, just send it back. https://www.google.com/search?q=ProScan+Elite+tablet%2FDVD+Player You will see in this link that it is a known issue. https://www.google.com/search?q=ProScan+Elite+tablet+DVD+Player+won%27t+connect+to+WiFi ..
2/28/2024 5:17:16 AM • Tablets &... • Answered on Feb 28, 2024
Can't remember my password to unlock my JPay tablet?
Forgot Password
JPay http://www.jpay.com > ForgotPwd Please enter the email address associated with your JPay account. We'll send you an email with instruction on how to reset your password.
Have a jpay tablet and trying to unlock it. followed the
JustAnswer https://www.justanswer.com > Android Experts May 1, 2021 - Power off your Tablet. · Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ... · Choose ... 1 answer · Top answer: Hello and welcome to JustAnswer, I'm Tauseef, Technology Expert with JustAnswer and ...
I was recently released from prison and I'm trying to unlock
JustAnswer https://www.justanswer.com > Mac Problems Jul 6, 2021 - Please enter the email address associated with your JPay account. We'll send you an email with instructions on how to reset your password. https ... 1 answer · Top answer: Hello. Welcome to JustAnswer.com [//JustAnswer.com], an independent paid... ..
2/22/2024 4:57:08 AM • Tablets &... • Answered on Feb 22, 2024
Crystal View NB4-3/5788 7 inch Netbook. I forgot the password, no volume button. How factory reset with no volume button.
Question edited for clarity. You can't. You have to fix the Volume button first as it is the thing that initiates the reset. But you can try the volume Up button instead. Some version of Android will work with either or both Up and Down.
How do i hard reset my crystal view net book 7in NB4-3/ ...
Ask Me Fast https://www.askmefast.com > How_do_i_hard_reset_... If your tablet is on, power it off. Press and hold Power until the device powers on, then immediately press and hold Volume Down (while still pressing Power).
How to reset my crystalview nb4-3/5788?
Ask Me Fast https://www.askmefast.com > How_to_reset_my_cryst... "Do the manual hard resetting for your crystalview xt netbook step..." · 1. Hold Power button + Home Button + Volume UP · 2. Hold Power button + Home Button · 3. https://www.google.com/search?q=Crystal+View+NB4-3%2F5788+hard+reset ..
2/11/2024 10:37:29 PM • Tablets &... • Answered on Feb 11, 2024
I recently got the iPad 15 Air, and I'm excited about its features. However, I'm curious to know if there are any hidden tips or tricks that users have discovered to enhance the overall experience..
Multitasking
take advantage of split screen multitasking to use two apps simultaneously. Swipe from the right edge of the screen to open the dock, then drag an app to the left or right side of the screen.
1/26/2024 3:38:27 PM • Tablets &... • Answered on Jan 26, 2024
The android process in my smart eurostar tv. screen has stopped - how can i fix this problem
eurostar tv problem fix boot issue remove tv from power outlet hold down the power button and volume less button (negetive button) to boot make it boot in usb or auto reset from default software if it does not work then you need to download the correct motherboard firmware or software and format the usb fat32 and copy into it firmware files are avalable below my button did not work so removed firmware you need a telegram account can be downloaded from the link below https://gofile.io/d/M98jbz ( if this link not working then download from telegram account this is for eurostar 32 inch tv ) original link from telegram here https://dipelectronicslab.com/eurostar-t32sled-a14-update-software/ other webiste wheich helped me https://www.kazmielecom.com/ Try the key combination if inverted screen and colour https://www.youtube.com/watch?v=pZsGDgD6JQQ if the service mode does not come then use the command when the input selection menu is open and using the remote the following command menu 1147 menu 8896 menu 2580 source and 2580 source and 308(this worked for me it worked when i was after reset i selected inside tv then i open source menu in cvbs1) source and 208 search youtube if you are still not able to open there are videos where people show menu and number in source option 1) in the service menu if your screen a)if inverted screen issue go to panel settings LVDS mirror mode if on then off it (if off then on it) b)if clour is inverted LVDS map change it to next option (if vesa change to jeda) there is any other issue this both website hav tutorial for any other isssue
1/18/2024 5:25:00 PM • Tablets &... • Answered on Jan 18, 2024
2answers
User manual for a supersonic windows tablet
Contact manufacturer to request assistance. Unable to identify which supersonic model it is. You can add information to your question using Comment menu. http://supersonicinc.com/index.php?route=information/creator&form_id=47
12/26/2023 12:03:31 PM • Tablets &... • Answered on Dec 26, 2023
2answers
How do I connect my PIXMA ip2820 to print from my google tablet
Methods that Setup Canon Pixma Ip2820 Printer Easily:- 1. Keep your Canon Pixma iP2820 printer on a place where you can handle it easily. 2. Insert the cartridges into the preferred slots. 3. Connect the power cable of the printer to complete the printer setup process. If the Set-up does not work To Setup Canon Pixma Ip2820 Printer, you want to join with Printer Error Support experts. You can also follow the easy steps to Setup Canon Pixma Ip2820 Printer are given below in the BLOG link. canon-pixma-ip2820-driver-software-for-windows-10-8-7-undefined-undefined-0.png
12/18/2023 2:57:59 PM • Tablets &... • Answered on Dec 18, 2023
Why did my brand new Naxa tablet stop charging?
If it is new it is under warranty. It looks like your model is an NID-1055 not an NTD-1055. Check the charger output with a multimeter or use a charger that is known to work. The identifies where the fault lies. https://naxa.com/supportcenter/warranty/ https://naxa.com/wp-content/uploads/2021/02/Naxa-Catalog-2.pdf ..
12/16/2023 6:48:29 AM • Tablets &... • Answered on Dec 16, 2023
I have a Intel education tablet model TR10CS1. It's not powering up and it's showing a USB sign and then shuts off. What can I do to fix it?
Question edited for clarity, punctuation, sentences, typo and CAPS. It is simply telling you it is out of battery power and needs charging up.
12/11/2023 9:16:14 PM • Tablets &... • Answered on Dec 11, 2023
Trio Mach Speed Stealth G2 Tablet - Teal in Color- 7" Dual Core Android 4.0 Internet Tablet with Google Play Store Logo
3 questions posted
Top Trio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Trio Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Trio Tablets & eReaders
Most Popular Question
get tablet get off 9dualcore screen
  • Tablets & eReaders
