20 Most Recent Samsung Galaxy Tab S 10.5" Tablet - 16GB, WiFi, Titanium Bronze Questions & Answers
if the device has not had charge in the battery you need to plug it in when red light goes off take charger out fot 3 secs.place back in and do it again in 15+minutes it WILL come on
Samsung Galaxy... | Answered on Jan 15, 2016
restart your tab in safe mode.now try your picture if it works then some of your installed app malfunctioning. delete all apps which are not come with your tab.
use antivirus and install your desired app again
for safe mode try u tube
Samsung Galaxy... | Answered on Nov 11, 2015
go to adobe.com. click on flash player. download.
Samsung Galaxy... | Answered on May 17, 2015
Probably a plug has come off inside... Time for a repair.
Samsung Galaxy... | Answered on Apr 11, 2015
Take it to the geniuses... (Apple) or any other tech support that you have with the new unit. Those guys love this type of problem!
Samsung Galaxy... | Answered on Apr 05, 2015
My first question would be, do you have the factory charger? If not is your ac adapter the right volts and mah? If not you may be experiencing a " trickle charge. " This is where the device is charging but only at a trickle like speed. This happens often with Apple products, when they update all your previous charging cords are useless. Try using a new updated usb charging cord too.
Samsung Galaxy... | Answered on Mar 05, 2015
You should receive updates automatically If you go into settings on the top click on General then scroll down to the bottom of the left hand column then click about device then on the right at the top is software update click that it will show when it was last updated under that is Auto update make sure you have that checked then you will always have the latest updates.
if you go back to about device you can then see model number, android version and other details. I have android version 4.4.2 at the moment everyone gets the latest updates at different times you just need some patience.
Hope this helps
Samsung Galaxy... | Answered on Feb 15, 2015
there is a small reset hole in the edge use paper clip to hold for 5 seconds see if fingerprint option reappears . post picture of opening screen , and use edge of piece paper to clean debri around print sensor button.
Samsung Galaxy... | Answered on Jan 17, 2015
REGARDLESS of what the initial notice says . open the drop down menu by swiping from the top notice line downward . tap the wifi icon and it will turn off. then turn it back on and tape the gear icon that will open settings , tap the wifi line to open the wifi settings. you should see your network there and be able to sign on.
you should start with a blank browser page just type in a website or topic. it should go to the site .
also try installing firefox from the store and then use the desktop icon to open the browser.
if you still have problems comeback and describe.
I have 3 galaxy products Tab 4 ", Tab S 8.4" and note 3 smartphone
all using kit kat. so i should be able to walk you through this one
You just touch them. Slide your finger either side of the home button ,the home button doesn't light up at all.
Samsung Galaxy... | Answered on Jan 02, 2015
I don't think you will get a reply as that is the type of question that would be asked by someone that isn't the genuine owner.
Why don't you call Samsung if you registered your machine when you got it.
  1. Power on your tablet.
  2. On the home screen, tap the App button.
  3. Tap the Screensaver app.
  4. Tap Enable Screensaver to turn the screensaver mode on or off.
  5. You want to turn off the screensaver!
Samsung Galaxy... | Answered on Dec 29, 2014
try download to other computer and then print it out?
Samsung Galaxy... | Answered on Dec 20, 2014
if we knew what GMOD was perhaps we could .
Samsung Tab... | Answered on Oct 01, 2019
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Samsung Tab... | Answered on Oct 03, 2018
Samsung Galaxy Tab S 10.5" Tablet - 16GB, WiFi, Titanium Bronze Logo
Popular Tags
17 questions posted
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Tab Samsung
  • Tab Samsung
Most Popular Question
switch screen but closes before type in
  • Tablets & eReaders
