20 Most Recent Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Questions & Answers
Check our video out on a very similar model. Had error code that your printer is having:
Epson WorkForce... | Answered on Sep 19, 2019
Ink levels are set by chips on the ink carts. You may be able to reset the chips with a "chip resetter", but that's not really recommended. Get refillable carts with automatic resetting chips...
Epson WorkForce... | Answered on Aug 29, 2019
I am on my second printer with the error. Epson explained it is a motherboard failure. The error is not caused by a PC or the software on it. Instead, this is a printer hardware failure.
After exchanging the printer, the replacement printer has now dies from the same error. The problem starts as blurry printing and progresses to the full hardware failure. Once the Hardware fails and you get the error code, there is nothing an end user can do. The motherboard needs to be replaced.
My printers were working fine up until I swapped out the factory cartridges that shipped with the printer. In both of my cases, there were no issues or symptoms until I started using the Epson XL cartridges. As soon as I installed those, the symptoms started to show. Within a couple of months after swapping in the XL cartridges, the motherboard dies.
Options:
1) Call Epson and complain, make them log the details even if it is out of warranty. This helps establish the pattern and knowledge of the issue.
2) Swap printer if under warranty. They may want a credit card to charge in case they do not receive the bad printer back. Just resend it in the box the replacement came in. Epson supplies shipping labels and covers the shipping costs.
Epson WorkForce... | Answered on Aug 21, 2019
You may need to clean the rubber rollers. I have attached videos on how to do so.
How to clean ADF Rollers:
Clear Epson ADF Error:
if you face any issue while using printer then visit here :
http://toshiba.hpsupportnumbers.com/toshiba-printer-customer-care
Epson WorkForce... | Answered on Jun 17, 2019
If you are lucky, the 0xF4 error indicates a foreign object (a scrap of paper) in the gears. That would translate to PF driver mechanism overload. Another cause would be a contaminated encoder scale. Fixing either of these will require you to disassemble the printer. Here are some tips for taking apart the printer: https://www.ifixit.com/Guide/Repairing+EPSON+B-510DN+Error+0xF2+or+0xF3/11767 .
However, the 0xF4 error could mean that the encoder board or the motor have failed. These errors can only be fixed by a service technician. If your printer is under warranty, you should call for service. Otherwise decide if you want to risk taking it apart and finding that you can't fix this error. It may be cheaper to replace the unit.
I hope this helps.
Epson WorkForce... | Answered on Jun 20, 2016
If you wish to get some details; check the site linked here. Pull up older posts.....
http://electro-medical.blogspot.com/
Two places to check and make changes. One is on the printer menu itself. Hit menu and navigate to print options. The second will be on your computer. When you go to print something a menu will pop up for a printer selection. It will also have an advanced button. Hit that and it will get you into an area to change the printing in multiple ways.
Epson WorkForce... | Answered on Feb 10, 2016
Turn the printer unit ON
2. Pull the power plug from the back side of it
3. wait 1 min
4. Plug unit back in
5. wait 3 full minutes
6. try to print does the error still exist? If yes continue below
Locate one piece of CARD STOCK paper and manually feed it up against the feed assembly and into the feed.Must be CARD STOCK PAPER, regular paper will not work. the idea is too dislodge any pieces of paper that may be broken off inside the rollers, and not visible to the eye. Repeat this process until the error goes away.
If you continue to experience problems, PLEASE RESPOND TO ME
Epson WorkForce... | Answered on Oct 14, 2019
I WOULD TRY THE EPSON WEBSITE AND THEIR TECH SUPPORT
Epson WorkForce... | Answered on Jul 04, 2019
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Epson WorkForce... | Answered on Feb 24, 2019
The process is quite easy, here is a short tutorial on it:
Solved How To Reset Epson Ink Cartridges
Epson WorkForce... | Answered on Sep 10, 2018
Epson WorkForce WF-4630 Wireless Color All-in-One Inkjet Printer Logo
11 questions posted
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
WorkForce Epson
  • WorkForce Epson
Most Popular Question
printer not reacting print mean when
  • Office Equipment & Supplies
