20 Most Recent
SanDisk Sansa e130 MP3 Player Questions & Answers
Will not turn on with new battery
Well it depends where you are, are you in New Zealand?
Try reseting the player if it has one other wise take it to an electronic shop to get it fix.
Sandisk e130
Get out the battery and let the device "calm down" without any source of power for 5-10 minutes. After that push the menu/start button, hold down for 30 or more seconds and holding down, insert the battery. It has to reset the power circuitry and should help.
Can't open SD camera card--error message.
1. Do not save any new file to memory card.2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.3. Download a recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
SD Card Photo Recovery4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.You may refer to this tutorial
Recover files from SD Cardhope this helps.
Photos says UnsupportedMediaFormat
You need to use the supplied Sansa Media Converter program to convert and transfer photos (and videos). If you don't have the SMC, you can download the Windows version from
http://www.megaupload.com/?d=3IPZO6Q0
How do i get the player to read mp3s from an sd
It won't. However, if they're on a microSD card, then they need to be in a folder named "MUSIC". Videos and photos will need to be in the internal memory, the Sansa will not read them from a card.
No funciona
BUENO no se que es lo que no funciona per muchos aparatos hoy en dia funcionan un dia oh no funcionaron del todo ...es necesario cargar toda la noche antes de usar cualquiera que usa bateria ...lo mejor es buscar otra cosa que muchos usan asi uno esa seguro que funciona..
How to download music from itunes
you will need the itunes programme which you can find just by going to itunes.com and on the page you can download the programme, and once installed you set up and account and search music and thn download any music you like, cheers
