20 Most Recent
Supersonic SC-89BL 7 Tablet W Android 4.1 Os Questions & Answers
How do I add a memory card to the Supersonic SC-89BL?
I don't think your tablet has a slot to add a memory card. Please check the user's manual; I might be wrong. If you can install a memory card in it, the user's manual will show where the memory card slot is located and how to install the card.
I need driver for piranha ultra II tab 7.0 compatable with windows 7
you don't really need driver's to transfer file, pic, doc, movies,etc...
just connect the Mini USB cord and on your tablet's notification area make sure you select USB connected.> select USB connect and the android will turn Orange.
You will see Drive E :(that will be the Tablet's Hard Drive Storage)
and F: (F) drive will be your external SD-card storage.
The android process in my smart eurostar tv. screen has stopped - how can i fix this problem
eurostar tv problem fix boot issue remove tv from power outlet hold down the power button and volume less button (negetive button) to boot make it boot in usb or auto reset from default software if it does not work then you need to download the correct motherboard firmware or software and format the usb fat32 and copy into it firmware files are avalable below my button did not work so removed firmware you need a telegram account can be downloaded from the link below https://gofile.io/d/M98jbz ( if this link not working then download from telegram account this is for eurostar 32 inch tv ) original link from telegram here https://dipelectronicslab.com/eurostar-t32sled-a14-update-software/ other webiste wheich helped me https://www.kazmielecom.com/ Try the key combination if inverted screen and colour https://www.youtube.com/watch?v=pZsGDgD6JQQ if the service mode does not come then use the command when the input selection menu is open and using the remote the following command menu 1147 menu 8896 menu 2580 source and 2580 source and 308(this worked for me it worked when i was after reset i selected inside tv then i open source menu in cvbs1) source and 208 search youtube if you are still not able to open there are videos where people show menu and number in source option 1) in the service menu if your screen a)if inverted screen issue go to panel settings LVDS mirror mode if on then off it (if off then on it) b)if clour is inverted LVDS map change it to next option (if vesa change to jeda) there is any other issue this both website hav tutorial for any other isssue
1/18/2024 5:25:00 PM •
Tablets &...
Answered
on Jan 18, 2024
