20 Most Recent
Samsung HT-DM550 System Questions & Answers
Switch on
Most likely, your unit has a condition known as DC Offset, meaning you have a bad amplifier. For more information, please visit my website at audioserviceclinic.com. Thank you.
My Samsung HT-DM550 shows "lock"
Be careful to do this with AC cable disconnected from AC outlet! If you have some experience with electronics, disconnect the wired plugs from power supply and discharge electrolitic capacitors to ground with a 330 ohm 1 watt resistor. Then reconnect the wired plugs. Be careful to do this with AC cable disconnected from AC outlet! Then connect to AC outlet and turn on the DVD player. You will see that DVD player restores to normal operation again.
[email protected]
Cutting out samsung ht-thx22
Start with checking your speaker wires, alot of times if you have positive & negitive crossing it will cause this issue
Cutting out
First check the speaker maybe one are on bad conditions and ready to burn,if they are fine the other cause be the audio amplifier IC
Problem when rading eny disks
This is a problem with the lens..
Get a lens cleaner CD with liquid and clean your DVD drive(just put two drops of liquid on CD and press play)
If this doesn't work you will need to replace the lens...The repair cost is not very high for replacing lens..
