20 Most Recent
Toshiba Encore 2 WT10-A32M Signature Edition Tablet Questions & Answers
My screen is frozen
If you just recently did the camera update, it is said (by quite a few) that is can crash the system and you will need to reset it.
*IF* this is the case with you (happened right after camera update), and you want to reset it to correct the recurring problem, consult your owner's manual on how to reset the device or you can see instructions in the online manual here:
https://www.manualowl.com/m/Toshiba/WT10-A32M/Manual/424925?page=42
Good luck
On my toshiba tablet,I forgot my pass word.how do I reset it?
Not sure about specifics on toshiba tablets, but wanted to suggest that on other tablets you can hold the up volume(sometimes others its volume down) and power button at sane time for about 10+seconds and a menu will pop up for a rebooting, safe mode, and factory restart(which erases and reboots from scratch) worth a shot.. Yet, be careful what you select if it works.. Don't want you to erase stuff if you don't want to.... And btw most tablets have a little pin size hole either under the camera lense or on side that something like a paper clip can push a reset button... But don't think that helps with password.. Just if it freezes up and won't shut down... Good luck.. Sorry if this doesn't help...
