20 Most Recent Samsung HLP4663W 46" Rear Projection HDTV Questions & Answers
The DLP chip is failing in your machine and will have to be replaced. Samsung use to cover this problem under their "white dot warranty" but I have not dealt with samsung in a while. You can call 1-800-samsung to find ou if it is still covered.
Samsung HLP4663W... | Answered on Nov 26, 2019
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
Samsung HLP4663W... | Answered on Nov 18, 2019
it is probably the color wheel going out. this is something a technician should do. can call 1-800-samsung or go to samsung.com for nearest service center.
Samsung HLP4663W... | Answered on Jul 01, 2019
I would have the Power Supply board and the Ballast replaced. Samsung recommends replacing both these items together. You can call 1-800-samsung to find the nearest authorized service center.
Samsung HLP4663W... | Answered on Jun 20, 2019
Sounds like the color wheel is not turning properly. I would recommend calling 1-800-samsung to set up repair with an authorized service center. I would not try to replace it yourself. The part costs $120.00- $180.00.
Samsung HLP4663W... | Answered on Jan 23, 2019
If it is new then return for replacement as it is a screen fault
Samsung HLP4663W... | Answered on Sep 12, 2017
Check the fan is not jammed.
Samsung HLP4663W... | Answered on Jun 10, 2017
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience....
http://electro-medical.blogspot.com/
Samsung HLP4663W... | Answered on Mar 14, 2016
sounds like the color wheel has gone out
Samsung HLP4663W... | Answered on Feb 02, 2015
If you can access the three projector lenses you will probably find them covered in dust, this shifts the light slightly giving a blurry 3D effect on the screen. Clean the dust off with lens tissue and window cleaner or a cleaner made for glasses and this will restore your picture.
Samsung HLP4663W... | Answered on Sep 08, 2014
Sounds like light engine or DMD board is going out. Is it on all inputs? when did it start doing; after a move, part being replaced, power outage etc? Does the menu screen have the same issue?
Samsung HLP4663W... | Answered on Jun 23, 2014
I recently had this issue on my Samsung HL-R4667W. Did the new lamp (phillips) but it still wouldn't light up and was flashing the lamp light and then stanby. I started to remove the rear covers of the TV thinking maybe the wheel or ballast finally gave out. After removing the lower cover I noticed a wire hanging at a unusual angle from a circuit board. I touched it and it fell off. Traced the wire back to the main control board and found that it was a ground wire. I re-soldered it to the board and the TV fired right up. My other lamp was fine too. I hadn't moved the TV in 4 years and only once since I bought it in 2006 so I can't think of anything that would cause it to come loose short of bad soldering from the assembly line. That was a year ago and it works fine still.
Samsung HLP4663W... | Answered on Apr 02, 2014
Samsung HLP4663W 46" Rear Projection HDTV Logo
496 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
samsung hlp4663w color wheel
  • Televison & Video
