20 Most Recent Samsung HLP4674W 46" Rear Projection HDTV Questions & Answers
2answers
Samsung DLP Has No Picture or Sound
Each set is somewhat unique in terms of parts, could you please update this with the model number. With that I should be able to rpovide you with details.
Thanks,
Dan
1/30/2022 8:10:46 PM • Samsung HLP4674W... • Answered on Jan 30, 2022
Samsung hlp4674w - picture went to black and white
most likely caused by a bad color wheel.can call 1-800-samsung or samsung.com for nearest service center.
2/25/2019 4:41:12 AM • Samsung HLP4674W... • Answered on Feb 25, 2019
Samsung hlp5063w picture goes off , the sound
SUBSTITUIR O COLOR WEEL.
10/19/2012 11:01:34 AM • Samsung HLP4674W... • Answered on Oct 19, 2012
The `power botton flashes and the screen remains dark
The model number/brand indicated here (if wrong let me know) is a DLP set---means it uses a lamp---lamp is suspect number one.Lamp is customer replaceable and easy to change--if you locate it and remove it-(it has a screw or two and a handle--cartridge with lamp pulls out) it is a good idea also to look at the color wheel -the lamp faces the wheel--if wheel is shattered or missing pieces it is the problem.You are when pull lamp out looking to see if it is shattered inside--do not touch face of lamp with your hand and of course have set off and unplugged when you do this.If the lamp--Google the model number with "lamp" and you will find dozens of sellers.If the wheel is bad--do same to locate and You Tube has video instructions for replacing it---average people can do the repair themselves.4_25_2012_2_50_37_pm.jpgcolor wheel4_25_2012_2_52_05_pm.jpgTypical lamp cartridge (not yours but similar)SD TECH
4/25/2012 2:52:43 PM • Samsung HLP4674W... • Answered on Apr 25, 2012
My tv samsung tv sp4616hv turns off and on
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time. Based on the above method you must be able to locate the area of fault and solder the sections.
10/28/2011 1:00:51 PM • Samsung HLP4674W... • Answered on Oct 28, 2011
2answers
I have a Samsung HLP
hi,
You have to check is there is any faulty electrolytic capacitor in the power supply if so then this problem can occur. Check the power supply board for any budged or leaked electrolytic capacitor which will look like one the picture. If the electrilytic capacitor is faulty then the output current of the power supply drops and the tv will shuts off at a regular intervals.
OK
ajin_g_81.jpg ok
9/21/2011 4:05:21 PM • Samsung HLP4674W... • Answered on Sep 21, 2011
Samsung sp46l6hv. lamp keep switchin
One of the most reasons that the samsung DLP tv will stop working is that the emergency switch on the back gets caught in the wrong position and makes your tv to turn off. Try to check the switch it is located under the lamp cover door. Good day and best regards.
8/19/2011 12:13:34 PM • Samsung HLP4674W... • Answered on Aug 19, 2011
Green and red light flash
one more thing you need to look out for is the ballast. The ballast ignites the lamp. They both work and to hand.
Once more cause of the problem could be a power problem. The symptoms of lamp, ballast and power problems are similar.
I look forward to your reply.
Bye for now.
6/18/2011 7:20:23 PM • Samsung HLP4674W... • Answered on Jun 18, 2011
My Samsung DLP HD 46" TV just went Black &
Defective Color Wheel- Encompass parts Distribution 1-800-638-3328
3/6/2011 9:19:20 AM • Samsung HLP4674W... • Answered on Mar 06, 2011
Turn on tv...green lamp blinks several
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
11/17/2010 12:35:52 AM • Samsung HLP4674W... • Answered on Nov 17, 2010
2answers
I HAVE A SAMSUNG SP46L6HV REAR PROJECTION HD DLP
Before it went out, was the sound like a fan or high pitched in nature?
Lamp can be removed (is is customer replaceable) to see if shattered inside.
I suspect a bad color wheel, which is not hard to replace. See attached photo of color wheel.
Examine lamp and if not shattered do not buy one to try.
I am here to help you for free.
Comment here and I will assist you.
SD TECH
9/16/2010 4:26:13 AM • Samsung HLP4674W... • Answered on Sep 16, 2010
Cuando enciendo mi tv no da imagen solo parpadea
usted nesecita una lampara nueva le recomiendo que habla a samsung , ya que biene toda la lampara comple i con isntrucciones como reemplazar la lampara
9/3/2010 4:47:39 PM • Samsung HLP4674W... • Answered on Sep 03, 2010
DARK PICTURE ON MY SAMSUNG DLP/HD REAR PROJECTION TV
It sounds like you need to buy a new bulb, this is what usually happens when the bulb is burning out this bulbs are made to last 6000-8000 life hours
http://www.discount-merchant.com/
8/20/2010 11:09:25 PM • Samsung HLP4674W... • Answered on Aug 20, 2010
My hlp4676w is making a loud humming sound. The
HLP4674 is a good model number but the 4676 does not show.
It sounds like you have a color wheel about to fail. It can make a high pitched sound that can be mistook for a fan like sound and is quite common to fail in these sets--I will attach a photo--it turns at 14,000 rpm and sooner or later the bearings in the little motor get bad.
Confirm actual model number and I will get you part number====several sites have written and even video instructions for replacing it and the part averages between 80 and 130 depending on model--
This can be a do it yourself job depending on your skill level.
If you have any questions or need more help let me know.
SD TECH
4/5/2010 4:00:58 AM • Samsung HLP4674W... • Answered on Apr 05, 2010
The location of the lamp for
The lamp is in the rear of the set and is a square shape with 4 screws. You will need a Phillips screwdriver to remove the panel and then the lamp housing.
Here is a link to a simalar manual.
http://downloadcenter.samsung.com/content/UM/200408/20040817140040687_BP68-00283A-02Eng_0506.pdf
I hope that this helps you out.
Thanks for using FixYa
asnowman
9/24/2009 6:28:03 PM • Samsung HLP4674W... • Answered on Sep 24, 2009
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
8/28/2009 12:42:42 AM • Samsung HLP4674W... • Answered on Aug 28, 2009
I changed the bulb on my samsung HL-P4674W and the
It could be your Light Engine if so they are NOT cheap,look up UED for cost and part.union electronic ditr.
8/10/2009 9:47:18 PM • Samsung HLP4674W... • Answered on Aug 10, 2009
Samsung HLP4674W 46" Rear Projection HDTV Logo
30 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
samsung hlp4674w picture went black
  • Televison & Video
