20 Most Recent Samsung HL-R4667W Rear Projection Television Questions & Answers
Samsung hl-r4667w needs power cord reset to turn on
How much was it moved? It could have jiggled something loose or made an intermittent connection, try removing the bulb/lamp and put it back in to reseat it, it might be detecting a lamp issue due to a bad connection, or a lamp thats starting to fail, if you have a spare lamp you can try replacing it. If thats not it then it may just be something is failing due to age/heat in the tv and moving it caused enough shock to the part to go intermittent. Most commonly when a projection tv does this its a problem with the lamp, or the power supply board.
1/2/2018 10:59:09 AM • Samsung... • Answered on Jan 02, 2018
0answers
Where can we get information about r4?
There are many sites online that happen to be offering details relating to r4 3ds. These are generally especially designed for those people who are seeking online games gaming system at reasonable prices. for additional information please visit this website:http://www.r43dss.it/
10/4/2016 1:14:24 PM • Samsung... • Answered on Oct 04, 2016
Tv will not come on clicking sound and fan going and humming
replace the colour wheel and replace the lamp for the color wheel u may have to replace the whole light engine cos it house the colour wheel
7/20/2013 9:25:28 PM • Samsung... • Answered on Jul 20, 2013
Picture comes on and goes off
check for a lamp bad or the ballast that drives it.
12/22/2012 2:01:40 AM • Samsung... • Answered on Dec 22, 2012
Hl-r4667w/hl Bought the tv 2005 and just started a buzzing noise
Buzzing noise on that model is usually caused by a fan or the color wheel.
5/18/2012 6:50:16 AM • Samsung... • Answered on May 18, 2012
HL-R4667W vertical lines when I use any of the components and or AV inputs, but is ok with HDMI, any help?
Someone would have to look at a schematic to see where the HDMI comes in in order to know where problem is (what to replace).Since a/v jacks show same trouble it is well after the tuner and is likely located on the board connected to the jacks for input---an area that deals both with tuner and conventional rear inputs.A schematic or even a block diagram of signal flow in the set would narrow this way down to what you need to replace.Try to Google for this with the model number and words like block diagrams, service manual etc.One last foolish thought---have you removed the HDMI connection to see if other inputs clear up?
3/26/2012 5:20:35 PM • Samsung... • Answered on Mar 26, 2012
Component1 and AV imputs show vertical green lights
This is based on the model/brand posted with this question(Samsung hlr4667w) most likely on this set a problem with the optical light engine or even the digital board in the set.To do some easy research on this GOOGLE the model number with "problems" to see what you can learn on your own.
3/25/2012 3:50:26 PM • Samsung... • Answered on Mar 25, 2012
2answers
Samsung DLP 42" flickering green screen
Just unplug and plug back in. Worked for me.
Try it a few times.
May not work for everyone.
1/19/2012 7:05:05 PM • Samsung... • Answered on Jan 19, 2012
No picture no sound just replaced the bulb -worked
Check Lamp Fan if it is defective set will shut down to protect the Lamp.
10/18/2011 11:43:44 AM • Samsung... • Answered on Oct 18, 2011
After a loud pop, TV
I would say the next thing to replace would be the ballast for the lamp and if that does not work the power supply board may have failed. When I replace the power supply, I also replace the ballast at the same time.
6/1/2011 7:37:56 PM • Samsung... • Answered on Jun 01, 2011
Samsung HL-R4667W Rear Projection Television Logo
99 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
HL Samsung
  • HL Samsung
Most Popular Question
hl r4667w vertical lines when use any
  • Televison & Video
