20 Most Recent
Samsung HCN653W 65" Rear Projection Television Questions & Answers
Blue convergence
SINCE YOU HAVE REPLACED THE CIRCUIT BOARD,THE NEXT STEP WOULD BE CHECKING VOLTAGES GOING TO THE CONV. BOARD COMING FROM THE POWER SUPPLY CIR. BOARD.....IF NO VOLTAGE METER,,SOMETIMES, THERE ARE FUSES ON THE POWER SUPPLY CIRCUIT BOARD THAT SUPPLY THE NEEDED VOLTAGES FOR THE NEW BOARD YOU JUST REPALCED...UNPLUG THE SET,,CHECK FOR A BLOWN FUSE----I THINK THERE IS 2 OF THEM--ONE FOR A NEGATIVE VOLTAGE AND ONE FOR A POSTIVE VOLTAGE FOR THE CONVERGENCE BOARD..GOOD LUCK--SORRY, MIGHT NEED A TECH...TUNICA
Color wrong
Could be a bad blue TUBE. Samsung tubes were NOT too good.
Rangs tv service mode
If you wish to know more details surf this site for more
details. Service mode entry and
adjustment procedure to many brand televisions are given in detail. Search for your TV brand name by its search
box at the upper right of the display window.
You can get a solution. More
than Nine Lakh viewers cannot be wrong.
Picture has a sag in the middle, blurring the
okay that sounds like a problem in the horizontal circuit and vertical circuit.the module of those section wants to be replaced.only a tech can do the repair.look for a tech to repair your tv
I have no sound and
After the timer light blinks for a while say a few minutes do any other LEDs start blinking along with it? Please provide this info so that I can help you with your problem.
Sai.
My Samsung HCN653W 65-Inch Widescreen Projection
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
- Screen looks 3D, wavy, or has a shadow or shadows
- Colors don't line up
- One or more colors can't be adjusted when using the convergence menu.
- Screen is bowed or warped.
- TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
SOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
SOLUTION
Tv will not come on
Hello brexpress,
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Best regards
circuitcity
Is there a surround sound hook up on this model of
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as
