20 Most Recent
Filter Queen Defender Air Purifier Questions & Answers
Programing
Here is the link to the user manual;
http://www.filterqueen.com/pdf/defender.pdf
Hope this helps :)
Red Light on front of Filter Queen Defender
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
Orange light help
Did you find an answer to your orange light question? I have an AM4000 defender that I bought off Craigslist and thought I got a good deal on it. One minute after turning it on the red light came on. I tried to reset it but the red light won't flash so you can't reset it. I don't know if it's a filter problem or a circuit board problem and I don't want to spend $100 bucks on filters to find out it's a different problem. If you buy filters on e-bay, they're cheaper but if you spend $100 from a distributor then you reactivate the warranty. I'm sorry I bought it.
Filter Queen Defender red light will not blink
no with the red lite on it mean that you need to change your filter its a safety feature so you dont burn out your motor and also so you dont blow unpurified air through out your home
Defender rac- 4000a owners manual
Hi raslas59,
From the Filterqueen (HMI Inc) contact webpage at
http://www.filterqueen.com/contact-filterqueen-locate-distributor.htmlFor an authorized FILTERQUEEN Distributor in your area, please call 1.800.344.1840 (U.S.) or e-mail
[email protected].
They will help you contact the nearest distributor - can probable get one mailed out to you. I didn't see any link where you could download a PDF file.
If I can be of further assistance, or if you have questions, please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using
Fixya.com,
Jon
Mother gave me her filterqueen defender.. no
The light is a reminder to change the filter, it does not sense if the filter has been changed or not.
Red light
The red light indicates a filter needs replacing, see page 6 of the manual (page 9 of the pdf file)
If filters have been replaced and the light still flashes, then the reset procedure (described on the same page) should work.
If still flashing then there is a more serious, but probably fixable fault.
Hope this helps - ask again if you need more info :)
Where can I get a new electric cord
What are you looking for? If is just for house current for average use go to any well known hardware or places like Lowes or Home Depot or Sears..ask for or look 14 gauge on the tag..if for higher amp use such as portable air conditioners and 15--3000 watt portable heaters ask or look for 12 gauge wire..that should handle all your needs..good luck...
