20 Most Recent Insignia - TTL External Flash for Canon Questions & Answers
Where in my insignia is the sd card located
In the slot labeled: "SD/MMC," it goes there. Try it upside down if it doesn't fit.
2/16/2017 2:57:31 PM • Insignia Cameras • Answered on Feb 16, 2017
What does the card locked mean?
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
5/7/2012 8:06:39 PM • Insignia Cameras • Answered on May 07, 2012
The cd that came with
Welcome to Fixya
You can download the software by going to insignia website. Please click here.
Thank you dor using Fixya! If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
5/31/2011 3:33:38 PM • Insignia Cameras • Answered on May 31, 2011
Hi how can i put
Here is a tip that I wrote about how to find the manuals, drivers, downloads andsupport for Digital Cameras.
DigitalCamera Manuals, Drivers, Downloads, and Support How to easilydownload Pictures from Digital Camera
heatman101
5/5/2011 10:02:26 PM • Insignia Cameras • Answered on May 05, 2011
My daughter has an Insignia
This is happening probably because the cam's memory card is corrupted. This is common with SD memory that has been used extensively for a long time and it's likely not caused by any fault in the camera.
You can try formatting the card (go to my computer, right click camera, click format.) but this isn't likely to work really. You will have to buy a new card. Make sure you buy a good brand like Lexar or SanDisk. Hope that helped.
4/25/2011 10:34:52 AM • Insignia Cameras • Answered on Apr 25, 2011
Want to send my pictures
You didn't specify the model of your camera, so I'm going to assume it uses a memory card of some type.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
3/27/2011 5:57:19 AM • Insignia Cameras • Answered on Mar 27, 2011
Washed my battery charger by
It will depend on your exact model for costs, but Insignia is a Best Buy brand, so they should have the extra accessories you need.
If the cable you mentioned was the USB one, most models use a USB to microUSB cable which you can get cheaply at almost any electronics store.
3/25/2011 10:35:19 PM • Insignia Cameras • Answered on Mar 25, 2011
I have a 7.0 mega
There should be a button with a little lightning bolt on it. Press it and go to the option "Flash off"
3/19/2011 3:03:03 PM • Insignia Cameras • Answered on Mar 19, 2011
Camcorder memory card is lock
See picture below and you will see the locking switch protuha_36.jpg Hope I helped!
2/25/2011 12:23:09 PM • Insignia Cameras • Answered on Feb 25, 2011
The camera powered on lens
This is a common problem that occurs when debris gets in between the camera body and lens housing, get a can of compressed air attach straw and give one or two blasts of air "body and lens housing" failing that! start tapping the lens housing with the side of your finger "gently" if it works aim the lens toward the floor and extend and retract a few times to work any further debris out.
1/19/2011 4:15:12 PM • Insignia Cameras • Answered on Jan 19, 2011
Camera will not come on
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
1/14/2011 11:58:21 PM • Insignia Cameras • Answered on Jan 14, 2011
Video sound is low volume
The following post has mentioned your similar problem:do you really realize your electronic products
You can use the Up key to make the sound loud
1/7/2011 7:46:52 AM • Insignia Cameras • Answered on Jan 07, 2011
On this ColorPix camcorder no
The card has a small button on the side of it that unlocks it. Slide it to the side and back again.
Hope this helps
1/1/2011 4:28:17 AM • Insignia Cameras • Answered on Jan 01, 2011
I just bought camera 3
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
11/21/2010 6:31:33 PM • Insignia Cameras • Answered on Nov 21, 2010
0answers
No instuctions how to delete
If the pictures are in the memory card, remove the memory card and insert it in a computer that will accept that type of card. Go into "My Computer" and locate the card as a drive. Open that drive and see if you can access the files, then delete. You can purchase a card reader from Staples if you don't have one. You should be able to delete the pictures through the cameras' setup menu.
10/31/2010 11:43:49 PM • Insignia Cameras • Answered on Oct 31, 2010
Insignia - TTL External Flash for Canon Logo
0 questions posted
Top Insignia Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you an Insignia Camera Expert? Answer questions, earn points and help others
View Most Popular
Insignia Cameras
  • Insignia Cameras
Most Popular Question
card locked mean
  • Cameras
