20 Most Recent Samsung Galaxy Tab 3 7-inch, white Questions & Answers
Try restarting your tablet if it still is not working try restarting it again unstall a few apps download CM security app this should help speed up things on your tablet CM Security Antivirus AppLock Android Apps on Google Play if it keeps up try backing up your data on sd chip and factory reset your tablet good luck!!
Samsung Galaxy... | Answered on Oct 03, 2016
Have not dealt with Samsung but I'm sure they have a help desk. If it's like Amazon you just got to their site and look for a contact help desk.
Samsung Galaxy... | Answered on Apr 03, 2016
Need to restart your tablet good luck!!
Samsung Galaxy... | Answered on Sep 20, 2015
Hi Candi,
Depending on age I suggest you return it under warranty. If less than a year old you could reject it as not fit for purpose. If it's too old for this then I think that you should have it looked at by a technician.f
Samsung Galaxy... | Answered on Jul 10, 2015
Yes it could be
Samsung Galaxy... | Answered on Mar 10, 2015
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
Samsung Galaxy... | Answered on Feb 11, 2015
Need to know your signal strength and if you're connected with proper credentials. If the wifi signal is weak, the computer may disconnect to look for a stronger signal. Sometimes ipv6 is the culprit on older computers too. Disable that and use ipv4 only. There are multiple reasons for dropped internet so the more info about your system and the conditions under which the internet is dropped will help in diagnosing the problem without sending you on a wild goose chase.
Samsung Galaxy... | Answered on Dec 16, 2014
if we knew what GMOD was perhaps we could .
Samsung Tab... | Answered on Oct 01, 2019
Before performing the Hard Reset:
- In case your Galaxy Tab 3 7.0 can connect to a computer, Then it is better to make a backup of your saved data using Samsung kies software, You can read this Guide to learn how.
- But in case that is not possible, Then you can check that your phone's battery has enough charging level, Otherwise you should charge it.
Samsung Galaxy Tab 3 7.0 SM-T210 and SM-T211 Hard Reset Steps:
- Turn your Galaxy Tab 3 off.
- Take out any existed SIM or memory card.
- Wait for 10 seconds.
- Press and hold the Volume Up key + Home key, Then press the Power key.
- Keep pressing the keys until Samsung logo appears,Release all keys.
- Wait until you get Factory reset / System Recovery menu on screen.
- Use the Volume Down key to select Wipe Data / Factory Reset option.
- Use the Power key to confirm the operation.
- You need to use the Volume Down key again to select "Yes -- delete all user data"
- Use the Power key to confirm.
- After performing the hard reset, Select Reboot System Now option, And confirm it using the Power key.
- Now the phone will reboots, Wait for it to be fully on and then you can start using it.
New Hard Reset / Factory Reset Method Using Odin3 Flasher:
In case you cannot put the Samsung Galaxy Tab 3 7.0 Into Recovery Mode for any reason, Or the Normal Hard Reset operation does not solve your problem, Then you can use this new method to Hard Reset the device so easy, This New Method will reprogram the User area, And it can solve many software errors too, Just follow the steps below:
- Download and Extract Samsung Galaxy Tab 3 7.0 Hard Reset File ( SM-T210 ' SM-T211 ).
- Download Odin3 flasher.
- Put your phone into Download Mode.
- Run Odin3.exe
- Click on CSC button and Select the Hard Reset file.
- Connect your phone to PC via USB cable, And wait until Odin3 detects the phone.
- Click on Start button and wait until the operation done.
- Now your Samsung Galaxy Tab 3 7.0 will be rebooted.
- Done.
Samsung Tab... | Answered on Oct 03, 2018
try going google and typing in ---user manual for samsung a8 tablet-- if there is a manual available it will be in pdf version for download
Samsung Tab... | Answered on Feb 01, 2018
Tip
How to make my tablet run faster
The cache on your Samsung tablet is designed to make things run smoothly. But over time, it can become bloated and cause slowdown. Clear out the cache of individual apps in the App Menu or click Settings > Storage > Cached data to clean all app caches with one tap.
Speed up a slow Samsung tablet - Which Computing Helpdesk
https://computing.which.co.uk/hc/en-gb/.../209878085-Speed-up-a-slow-Samsung-tablet
Turn off or reduce animations. You can make your Android device feel snappier by reducing or turning off some of animations. You'll need to enable Developer options in order to do this. Go to Settings > About phone and scroll down to the System section to look for Build number.6 Aug 201411 tricks to make your Android run faster - Android Authority.
tablet running really slow Google Search
on Nov 26, 2017 | Samsung Tab Tablets & eReaders
You would get better response if you ask just once and provide all the details available. For example, is the screen flashing blue, or another light? Exactly which model Samsung Tab E are you asking about? Have you tried contacting Samsung tech support?
Samsung Tab... | Answered on Dec 01, 2016
Samsung Galaxy Tab 3 7-inch, white Logo
9 questions posted
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Tab Samsung
  • Tab Samsung
Most Popular Question
running extremely slow
  • Tablets & eReaders
