20 Most Recent Samsung UN55HU7250 Curved 55 Inch Ultra Questions & Answers
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
2/21/2017 5:23:52 PM • Samsung... • Answered on Feb 21, 2017
Our Samsung 55" 4K TV lost it's picture a few days ago. I'm hoping this is a common issue and is there is a particular part I can buy to change out myself.
Look at the T-Con board. It is located in the center of the TV. It has two wide flat ribbon cables going to the bottom of the screen. There may be a metal cover on it. The numbers on the board will identify it. Go here for parts: TV Parts Universal TV Stands DLP Chips ShopJimmy
3/11/2016 11:55:05 PM • Samsung... • Answered on Mar 11, 2016
I have a Samsung TV. Model UN55HU7200. When try to turn it on the red indicator light at the left bottom flashes and i can hear a Click -Click then flashes then click-click.
Sounds like a power board issue. Unfortunately this is a common problem in flat screen TVs. Typicality this happens after the tv is three years old or older. Some will last several years. The repair is almost cost prohibitive. The replacement board if you sent it out to a repair shop would cost approximately $190.00 and altleast two hours labor $180.00 for the repair. Most repair shops also charge for a diagnostic fee. That fee most likely would be around $50.00.
1/18/2019 11:52:57 PM • Samsung UN... • Answered on Jan 18, 2019
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://homenol.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM • Samsung UN... • Answered on Oct 27, 2017
Samsung UN40JU6500F had picture on intial power up, changed source and lost picture. Can't get it back, only sound. See faint images. Bottom back shows blue lights on. Inverter? Power board?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
7/27/2016 2:10:32 AM • Samsung UN... • Answered on Jul 27, 2016
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
4/1/2016 4:33:08 PM • Samsung UN... • Answered on Apr 01, 2016
2answers
Led tv will not power on
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
5/30/2015 2:13:51 AM • Samsung UN... • Answered on May 30, 2015
2answers
I got a 55 inch Samsung flat panel tv model # UN55D6000Sf Version H302 with standby light blinking 1 time in repeat. I have changed the power supply board, main board & tcon board but still no luc
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience. 25385779-zvi5jbxfx450ftsjwzjui5ep-5-0.jpg
5/30/2015 2:11:49 AM • Samsung UN... • Answered on May 30, 2015
3answers
How can I fix a 3/4 inch vertical black line on my Samsung UN60D8000?
When liquid drips onto the x buffer boards (located along the bottom edge of the display panel ) the liquid Will damage the ribbon cables that are connected to the display panel. Replacing the display panel may be the only way to repair the tv. I've been in the tv repair business for over 30 years.... Dan
5/30/2015 1:36:41 AM • Samsung UN... • Answered on May 30, 2015
HOW DO I UPDATE MY SAMSUNG LED TV FIRMWARE MODEL NUMBER UE46B8000XWXXU
Try opening your menu options and search for "updates" Usually when you set your TV for the first time it usually guides you to do this firmware update. Try acting like your are setting up your TV for the first time and maybe it will have a option for this.
4/3/2015 2:02:30 PM • Samsung UN... • Answered on Apr 03, 2015
LED TV strobing
new hdmi cable
9/8/2014 3:19:06 PM • Samsung UN... • Answered on Sep 08, 2014
0answers
Samsung ln60d60 frezzes every 10-20 seconds
Main digital board fault. Contact the authorized service center for Samsung. Gopakumar Gopalan Google
5/19/2014 3:08:13 AM • Samsung UN... • Answered on May 19, 2014
0answers
0answers
0answers
0answers
Un40b7000 the volume turn down by itself.
Main board fault. Contact any service technician; or the authorized service center for Samsung. This is not a user repairable fault. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. http://electronicshelponline.blogspot.com/
1/24/2014 11:45:21 AM • Samsung UN... • Answered on Jan 24, 2014
Samsung UN55HU7250 Curved 55 Inch Ultra Logo
2 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
UN Samsung
  • UN Samsung
Most Popular Question
our samsung 55 4k tv lost s picture few
  • Televison & Video
