20 Most Recent Samsung SV5000W VHS VCR Questions & Answers
The flat copper spring's lack of contact with the mechanism absolutely was the problem here! I soldered some copper braid on the spring and soldered the other end to a lug conveniently located on a bracket behind the right side of the drum.
Vodeo 99, you are right. This is a design flaw. And properly grounding the mechanism in this otherwise decent deck should rid you of the white flecks (that do resemble dropouts) in your picture!!
Samsung SV5000W... | Answered on Jun 14, 2019
Check the region coding of the discs. You are probably set for region 1 and the German discs are region 2
Samsung SV5000W... | Answered on Feb 11, 2018
Your chassis ground is intermittant. Remove the VCR cover and look just behind the head drum. You will see two copper tangs sticking out, these supply the ground to the grey chassis and are a pressure fit. Remove the 7 screws from the grey chassis, two are underneath the VCR, two on top near the VHS tape opening, and three larger screws are on top of the chassis (2 near back and 1 near front). This will allow you to lift the grey chassis about a 1/2" and you can then reach below the copper tangs and gently pry them up. Reinstall the 7 screws and the VCR cover and the snow will disappear.
Samsung SV5000W... | Answered on Apr 18, 2016
It is a Electrolytic capacitor of 1000Microfarad capacitance and operating voltage max being 16V
Samsung SV5000W... | Answered on Nov 14, 2011
The vcr has a power supply problem, the repairs will run the cost if not more than a new machine, if the tape is precious and you want to save it, the top will need to come off 2 to 6 screws to access the cassette tape, sometimes you can manually unload it by turning the gears towards you on the side of the basket, but if the tape is spewed or you are not sure how to proceed take it to a shop to have them deal with it.
Samsung SV5000W... | Answered on Feb 14, 2011
Try website like Remotes.com to buy an exact or very close to the original remote.
Samsung SV5000W... | Answered on Jan 06, 2011
your VCR deeds a good cleaning (pinch rollers, guyding posts and heads) NOT A DO IT YOUR SELF JOB ask a good VCR tech.
or one of the GUYDING POSTS is defective and is not retracting (more serious mechanical problem)
Samsung SV5000W... | Answered on Dec 31, 2010
Yes! If you look on the back it should say the voltage ratings. Beside that UK voltages can be as low as 220 at times and in some areas!
Samsung SV5000W... | Answered on Dec 03, 2010
Does the SV5000 have a coaxial (Channel 3 or 4) output? Connect that output to the antenna input to the old TV. If your TV is so old that it has only a 300 ohm antenna input (2 screws), just use one those old adapters that has 2 scew lugs on one end and a coaxial receptacle on the other, connect a coaxial connector between that and the VCR's coaxial output.
Samsung SV5000W... | Answered on Aug 04, 2010
I had the same problem with my VCR. The problem is not a dirty head. I was connecting the VCR to the A/V input of those new TVs with the digital tuners. I got rid of the problem by connecting the coaxial (analog Channel 3 or 4) output of the VCR to the Antenna input of the TV and tune to plain old analog channel 3 or 4. That way you apparently avoid the digital circuits and those blasted dropouts; Now the VCR plays perfectly on my new 42-inch TV..
check the tip in my profile
Samsung SV5000W... | Answered on Jul 18, 2010
you cannot fix this yourself,your audio heads and tracking may be out.need a tech to do the job.
Samsung SV5000W... | Answered on Jul 05, 2010
Do you have a picture with just normal playback of VCR? If the answer is no, then it sounds like the head might need cleaning. Use Servisol video 40 see image below:
Samsung SV5000W... | Answered on Jan 28, 2010
The problem has been solved. The failed electrolytic capacitor (1000uF x 16V) in the power supply circuit was found. The VCR was functional after the failed capacitor replacement. This filter capacitor needs to be high ripple current part, so, hopefully the new part (with unknown ripple current capabilities) will work fine.
Samsung SV5000W... | Answered on Jan 10, 2010
Hi and welcome to FixYa,
Initially, have you tried the RESET button on the front panel? This may have been proposed by another member of the site who responded ahead but as I am unable to view their solutions, I have to post it.
Offhand, should the above reset be not corrective, options then are:
  • consider a DIY (do-it-yourself) repair if and only if very familiar with electronic components & circuitry, use of a DVM/VOM, a soldering iron/station and safe working practices with electrically powered devices. Access to a Service Manual or at the very least, a schematic diagram would be a necessity;
  • should you be uncomfortable with a DIY, perhaps your best bet would then be to seek the services of an authorized Sony Service Center or a qualified professional.
If a DIY is being considered, preliminary check would be on the different voltages of the power supply (PS) board and the conditions of the power/filter capacitors. The schematic diagram of the PS board maybe referenced below.
In some instances, mechanical issues could also trigger the auto-shutdown such as the loading motor, gear, belt.
Good luck and thank you for asking FixYa. Merry Christmas.
Samsung SV5000W... | Answered on Dec 25, 2009
the machine monitors the pully speeds to make sure tape is actually moving properly .. if it isnt then it halts rather than spool off hundreds of feet of tape inside the machine .. what a mess that would be ... almost always the problem is an idler pully that operates the takeup reel .. the rubber gets hard or contaminated so that it slips .. if it fails to turn the takeup reel then every thing stops ... you an try cleaning the wheel if you can find it .. it usually under the transport mechanism (sometimes available if you can take the bottom off the unit) .. dont use alcohol .. you can use water or special idler wheel cleaner or even a pencil eraser .to clean it ... or for name brands there may be parts still available .. you can just replace the idler pully with a new one ... this requires more work than most people are willing to do ... and if you have someone repair it the cost is often more than a new machine .. if it gives you enough time you might try to fast forward all the way then reverse all the way .. do that a few times and it may clean the idler wheel enough to work for normal play .. ...
Samsung SV5000W... | Answered on Nov 22, 2009
Google and download driver magician and run it. See if that helps you find your video driver.
Samsung SV5000W... | Answered on Nov 09, 2009
Samsung SV5000W VHS VCR Logo
54 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
samsung vcr sv 5000w tracking problem
  • Televison & Video
