Hello, this is Ava with Think Crucial.
Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
There are a number of reasons why your Dyson cleaner shuts off intermittently. First, it maybe due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
https://www.thinkcrucial.com/search?type=product&q=dyson+v6
Ava B.
There are a number of things you need to do that may solve the issue you're having with your vacuum. First, make sure that your battery is charging and working. Second, check the MAX button. If the MAX button lights up and flashes when your Dyson cordless vacuum keeps pulsating on and off, hold the power button and depress the MAX button to turn off that function. You may have to try a few times to get the hang of it. And lastly, look for any blockages in attachments because the pulsating is caused by a lack of airflow as the motor is protecting itself by pulsating and then ultimately cutting out.
You can check this video tutorial which will teach you on how you may fix it:
Ava B.
Essentially, yes they are the same.
The DC59 and V6 share the main body in common in most respects, except for the Absolute or HEPA which features the post filter and is therefore different.
I hope this helps but if you have further questions please give the Dyson Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA), 0800 298 0298 (UK).
Best wishes,
Allan
two faults, mainly battery.
A flashing blue light indicates that there is no power, please charge the battery. A flashing amber light indicates that there is no power or a temporary fault (e.g. too hot/cold). A flashing red light indicates that there is a fault, please call the Dyson Helpline.
