20 Most Recent
Samsung DVD-V3650 DVD Player/VCR Questions & Answers
Samsung DVD-V3650 - Remote operation (on/off,
The issue maybe the
board in the players. Wipe the front to make sure the IR sensor isn't
being blocked by a smudge, and if it still is intermittent you can try
replacing the remote from the manufacturer. If both don't work the unit
will need to be replaced if the intermittent working on/off is too much to bear
5/7/2010 3:25:45 PM •
Samsung...
Answered
on May 07, 2010
Is there a way to change the region code for a
Hiu this code for DVD-3250, it may work for you.
1) remove disc and wait for "no disc" to be displayed
2) press "pause,, 3,1,4,1,5,9", Code-- will display.
3) enter code for region using numeric keypad( 09 may work for multizone).
4) press "pause, power"
alternatively DVD -V440
1) step 1 above
2) press"subtitle,7,6,8,8,4" then "9 (multizone), subtitle"
3) open & close drawer
Good luck
3/18/2010 1:29:10 PM •
Samsung...
Answered
on Mar 18, 2010
Split screen on DVD player
This sounds like a progressive scan issue (unit in P.Scan Mode) here is a C&P from the manual
Set "Alt Video Out"
Highlight "Alt Video Out", then press the RIGHT button to select
one of the following options:
• S-Video - Select this if you are using the S-Video OUT jack on
the rear panel to connect to a TV.
• Component - Select this if you are using the COMPONENT
VIDEO OUT jacks on the rear panel to connect to a
Progressive(480p) or Interlaced (480i) TV.
• See your TV owner's manual to determine what type of TV you
have.
- Interlace : Interlaced Scan mode will work.
- Progressive : Progressive Scan mode will work, and Video
and S-Video will not work.
• Press the Progressive button on the front panel if you have a
Progressive scan TV only. Otherwise, the picture will be
disturbed.
9/10/2009 6:30:57 PM •
Samsung...
Answered
on Sep 10, 2009
No video when playing videocassettes
Try checking that the cables are plugged in correctly, also try to make sure that the videocassette isn't damaged or dusty in anyway. Try using a cleaner as well. Hope it helps
Good luck and let me know what happens^^
3/31/2009 3:18:42 PM •
Samsung...
Answered
on Mar 31, 2009
