20 Most Recent
CELLULARVILLA Wallet Case For ZTE Speed N9130 Boost Mobile Pu Leather Wallet Card Flip Open Pocket Case Cover Pouch Pink Glitter Questions & Answers
I just bought a used ZTE N9130 cell phone when I charged / powered it up the screen is pattern locked. How do I factory reset this phone ?
To perform a hard reset, or factory reset, then there are a number of methods to try:
1) From the home screen, press Menu - Settings - Privacy - Factory data reset - Reset phone. It may ask for a password. Then select Erase everything
If the phone is totally unresponsive, even after a reboot, then try the following methods.
2) While the phone is turned off, press and hold the Volume Up and Volume Down buttons together. Then, while holding these, press and release the Power button (keep holding the volume buttons). The phone should turn on and a menu will appear. Press the Volume down button to navigate to the Recovery option. Press the Volume Up to select (if that doesn't work, use the Power button to select). A yellow triangle and an Android logo will appear. Press the Volume Down and Volume Up button together and a recovery menu should appear. Use the Volume buttons to move to the Wipe data/Factory reset option and then press Power to select. Again, use the Volume Down key to choose Yes and press the Power button again to select.
3) While the phone is turned off, press and hold the Volume Down button. Then, while holding, press and release the Power button. A menu should appear. Use the Volume down key to go to Clear Storage. Use the Power button to select the option. Then when asked to confirm, press Volume Up for Yes.
4) While the phone is off, press and hold down Volume Up + Home + Power buttons at the same time. Then release the buttons when you see the Logo. Use the Volume Down button to go down and the Home or Power key to select. Choose the Wipe data/Factory reset option. Then Select Yes to delete all user data. Then choose to reboot the phone.
5) A final method is to enter the code into your phone's dialer: *2767*3855# This method will not give you an option to reverse the process, so be careful! This method will only work if you can boot into your phone. - See more at: http://www.phonetipsandtricks.com/tips/zte-warp/how-to-hard-reset-factory-reset-31/#sthash.9JNbyTkc.dpuf
I need the reset code for Cash Power 2000 prepaid electricity meter.
How do I reset my cash power meter?
Reset your meter by pressing I, BLUE or # button, this is needed to ensure the 2 parts of your meter initiate connection again. This action should reset your meter. Please note, this error is not a technical error and you should never insist a technician comes out for this.
4/17/2024 6:33:31 AM •
Cell Phones
Answered
Yesterday
GPX Media Player model MT851B. My touchscreen doesn't respond on it. How do I fix it
There doesn't seem to be anything online to suggest how to do a reset or recalibrate the screen.
You could try three things
Look for a tiny Reset hole in the back.
Connect it to a computer and in Windows Explorer see if the is any useful right click commands?
Or leave it running until it runs out of power, wait 24 hours before recharging.
4/9/2024 3:30:50 AM •
Cell Phones
Answered
on Apr 09, 2024
Track my phone thats is off
This can't be done. If the phone is powered off or the battery dies, the GPS isn't working and it can't be tracked. If you go into 'Find my Phone' you can see the last position it was located, but you won't be able to get a current position if the power is off or dead.
4/8/2024 2:35:20 PM •
Cell Phones
Answered
on Apr 08, 2024
I bought my Mom a Flip phone and she has Straight Talk service. The phone will not ring when someone calls in. HELP!
I would check 2 things. First, make sure the phone doesn't have a 'sound off' button on it. Many phones have a button on the outside that turns off any rings, beeps, etc. Make sure if that exists that its not turned on. If you either don't find one or its not engaged, then I would call Straight talk and have them ensure that the cell service is properly 'provisioned' for your Mom's phone. Sometimes the cell companies screw up and the phone won't ring. Either of those will hopefully do the trick!
4/8/2024 2:33:38 PM •
Cell Phones
Answered
on Apr 08, 2024
How doe i connect coolpad model # 5560s to the internt
Connecting a CoolPad 5560 to the internet ... you need to connect your machine to your router either wirelessly, (follow the router instructions) or wired with an RJ45 cable.
If wireless look for the router, type in the routers password and save it.
That is it you will be on the internet, if the router is connected to your internet.
Likewise for hard wiring (and you won't need the password).
4/7/2024 5:50:37 PM •
Cell Phones
Answered
on Apr 07, 2024
