How do I configure my NIC with a static IP for use with a SpeedTouch Home?If you are using an Alcatel SpeedTouch Home (without a router), a PPPoE client such as NTS, WinPoet, or RASPPPoE, and are experiencing stalls and freezes while surfing or connected, it may be that your NIC is not configured correctly.
You must set a Static IP on your NIC. If you have it incorrectly set for "Obtain IP automatically" it will be looking for a DHCP server that does not exist. During the time the NIC is searching for the DHCP server you will experience stalls and freezes. An incorrect NIC settings will also cause the PC to take a longer time to boot up. This FAQ has two sections:
Section 1 - NIC Properties for Windows95/98/ME
Section 2 - NIC Properties for Windows2000/XP
Section 1 - NIC Properties for Windows95/98/MEStep 1Click on
Start ->Settings ->Control Panel ->NetworkStep 2Once at the Network Window scroll down and look for the first entry in the box marked
Internet Protocol (TCP/IP) that is associated with your hardware ethernet card (ignore dialup, AOL, and VPN type bindings). Select the correct Internet Protocol (TCP/IP) entry and click
PROPERTIES.
Actual screen shots may vary
Step 3Select the
IP ADDRESS tab. Select
Use the following IP address and enter
10.0.0.1 and
255.255.255.0 into IP address and subnet mask fields respectively.
Do not click on
OK yet.
Step 4Select the
GATEWAY tab. Enter
10.0.0.138 into New Gateway field and click on
Add. Click
OK.
Step 5Close all windows and restart the PC.
Section 2 - NIC Properties for Winows2000/XPStep 1Click on
START -> SETTINGS -> CONTROL PANEL -> NETWORK CONNECTIONS. Right click on
Local Area Connection and select
Properties Step 2On the
General tab highlight
Internet Protocol (TCP/IP) and click
PROPERTIES.
Step 3Select the
GENERAL tab. Select
10.0.0.1,
255.255.255.0, and
10.0.0.138 into IP address, Subnet mask, and Default gateway fields respectively. Click
OK.
Step 4Close all windows and restart the PC.
