20 Most Recent Samsung DVD-V90K Multisystem DVD/VCR Questions & Answers
If the dvds which are "all regions" are recorded from a computer, your dvd player may not play them. I assume the dvds which have a region code have been professionally prepared. Sometimes, the cheap dvd players will play anything while the more sophisticated ones will give you trouble unless everything is just perfect.
Samsung DVD-V90K... | Answered on Jul 26, 2011
While looking through some forum posts i found the way to fix the problem. It takes a bit of fiddling around but it does work... I tried it out last night.
Firstly you need to put a DVD of a different region into your player and wait for it to start to read the DVD before you commence the procedure... it takes a bit to get the timing right.
when the DVD can't be read it, on screen Eject Disc will come up
Press Repeat & Hold 3 Seconds (it may work using either repeat button on the bottom, i tried both.
Press 76884
After entering those 5 digits, you should see a number in the top left corner of the screen corresponding to the current region (4 being Australia region)
Press 9 for "auto-region" mode ie. Region Free
Turn Off Machine
and there you have it. The timing is crucial so start trying as soon as the DVD is in. It took me 5 goes before it worked.
You will notice that it may take a bit longer for the other Region DVDs to be read then normal but it's only a few seconds longer.
Samsung DVD-V90K... | Answered on Mar 18, 2011
Check your DVD player's color system, most multi system dvd player has to be set(PAL or NTSC) manually, NTSC for American standard. Look for this button could be a mechanical switch at the back or at the menu. Some machine need to reboot after setting. Hope this helps
Samsung DVD-V90K... | Answered on Mar 04, 2010
I want unlock my samsung HT-TZ212 to multi region
Samsung DVD-V90K... | Answered on Jan 31, 2009
Multiregion samsung
It is suppose to work on most samsung dvd players
Use by your own risk
Turn on
Press repeat or subtitle button
  • for Region 1 press 2, 9, 3, 3 and 4
  • for Region 2 press 3, 8, 7, 6 and 7
  • for Region 3 press 5, 6, 7, 3 and 2
  • for Region 4 press 7, 6, 8, 8 and 4
  • for Region 5 press 5, 3, 8, 1 and 4
  • for Region 6 press 2, 4, 4, 6 and 2
Press 9
Turn off and on again
Samsung DVD-V90K... | Answered on Jan 19, 2009
Follow the instructions on the following page to change the zone of your player:
http://www.answerbag.com/q_view/775274
I followed the instructions without updating the firmware and it worked for me. Hope this helps.
Samsung DVD-V90K... | Answered on Nov 01, 2008
Get an LG.. went through TOO many Samsungs.!!
Samsung... | Answered 5 hours ago
That's impossible unless is it possessed by the devil. If it is unplugged, there is no power to it. It has no internal battery apart from a tiny one on the motherboard to keep its memory. It is more likely to be a carbon monoxide alarm or similar. See the link.
https://www.google.com/search?q=Samsung+TV+keeps+beeping+about+every+30+secs
Samsung... | Answered 6 hours ago
try changing input or source if ok try audio settings
Samsung... | Answered Yesterday
could be a few issues to consider. The video processing card is faulty. hold a flashlight close to the screen and see if you can see the images. if yes, your powerboard has a failure and the backlight has failed. either way, get a repairman to attend to it.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
did you try a hard reboot?
Samsung... | Answered 2 days ago
The backlight is controlled by the powerboard.
Samsung... | Answered 3 days ago
It is possible the harmonic balancer/dampener on the engine has given up the ghost. Worst case would be the transmission torque converter is acting up.
https://youtu.be/vM-bz_oBuus
Here ya go, this is for the HCL5515W. Copy and paste into browser. I hope this helps.
http://downloadcenter.samsung.com/content/UM/200508/20050809174343484_AA68-01509D-00Eng_1019_book.pdf
Samsung... | Answered on Dec 04, 2019
You should call 1-800-samsung and they will tell you what to do or who to call to get it repaired under samsungs' warranty. It sounds like the power supply board is defective.
Televison & Video Logo
10 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
region codes
  • Televison & Video
