20 Most Recent
Blu Studio 5.0 II D532L Unlocked GSM Dual-SIM Android Smartphone - Black Questions & Answers
Have Blu View 3 that can't make or receive calls, can you please help me?
I remember reading somewhere about an issue with so called off brand phones(Non-Flagship)... as im in the same boat(Using Cubot Brand) and talking with my service provider today. they stated my phone isnt on the list or compatable with the at&t network anymore(atleast the calling part of it) you should still be able to use data & text. Lucky i already have a third party app for a 2nd phone and also use google voice, both of which let me make calls using my data. and if i need to contact someone i can either send a voice/text message as normal.I have read somewhere that i believe blu is trying to get onto the att network. So hopefully they do because ill just switch back sense they are a good phone company. Hope this info helps.:Edit: Even if it is 4g LTE, also spoke with a friend who has a 5g non-flagship whos carrier uses att and she isnt able to make calls from the phone but the speeds are still there. So hopefully something gets fixed because I believe this is some B.S. to lock us out because we dont want to pay for a iphone or samsung
How do i block a number? BLU advance 5.0
1. Touch the icon that says "Phone" on your main screen.
2. Click on the entry for the number you want to block under "logs."
3. Press the menu button on your BLU advance 5.0.
4. Select add to "reject list."
How can I retrieve deleted text messages
heHello,
Two ways you can get back yourdeleted messages from the phone.
1)From the service provider.
WHAT YOU NEDD TO DO TO GET BACK THE MESSAGE FROM THEM IS TO CALL ON THEM
FROM THE CUSMER CARE CENTER.
2)From the other side that the message was send from. Thanks.
Why when I hit contacts google pops up first
Googled Blu phone. Blu phone is an android device. Android is another name for google. Specifically android is googles operating system. If you were looking for another contact list you will have to download an app and set that up. But on this part you are on your own for now. I an an Android user and like it that way.
Hope this helps.
How do I make my BLU vivo picture gallery visible on a windows computer so I can transfer pictures from phone to PC?
With a USB cable connected from phone to PC, Windows explorer should detect it as a 'Mass Storage Device'.
This should also show up in 'My Computer' as a virtual drive.
If not, you may need to first install BLU driver for your phone.
Once set up correctly, you can configure the device's 'Auto-Load' function to automatically download media from the phone when USB is plugged in.
Otherwise you can navigate via the 'My Computer' screen to explore files on the virtual drive.
My BLU cell phone is blinking and keys are not properly functioning
One or more of your keys may be slightly pushed in causing the phone to blink and the other keys not function properly.
Turn off your phone, remove battery and clean your phone keys with a qtip or a soft wipe. Be sure to not soak where solution is dripping, that will cause further damage to your phone. you want to dampen the qtip or soft wipe and gently clean the keys. As you are cleaning the keys you may notice by touch (not visually) one or more keys may be pushed in. Genlty rub the part of the key pushed until it releases.
Continue to clean all the keys and the outer part of the phone itself. Replace the battery, turn on phone. Hopefully this resolves the problem.
