20 Most Recent
NordicTrack NORDIC TRACK SL705 Console Model Number NTC05940 Part Number 211946 Questions & Answers
NordicTrack 1750 Commercial motor not running.
It seems like you have already performed several troubleshooting steps on your NordicTrack 1750 Commercial treadmill. Since you have replaced the motor control board and checked the wiring, here are a few additional suggestions to consider before replacing the motor:
- Reset the treadmill: Turn off the treadmill, unplug it from the power source, and wait for a few minutes. Then plug it back in and turn it on. This can sometimes resolve temporary glitches or issues.
- Calibrate the treadmill: Check if your treadmill has a calibration process outlined in the user manual. Follow the instructions to calibrate the speed settings and ensure they are properly aligned.
- Check the motor brushes: The motor brushes are responsible for transferring power to the motor. Over time, they may wear out and cause issues. Inspect the motor brushes and if they appear worn or damaged, consider replacing them.
- Test the motor with a different power source: If possible, try connecting the motor to a different power source or outlet to rule out any issues with the electrical supply.
- Consult a professional technician: If you have tried the above steps and the motor still doesn't run, it may be best to consult a professional treadmill technician or contact NordicTrack customer support for further assistance. They will have the expertise and tools to diagnose and resolve the issue accurately.
How to Disassemble your Treadmill
Recently bought a NordicTrack treadmill online and was glad the treadmill 'folded up' for storage and transport. To my horror, the treadmill is very bulky even folded, and hard to get out of standard-sized doorways. This video was SO helpful with the disassembly. Like others who posted, I did have difficulty with the clip passing through the grommet, needed to push the clips through from the inside with a bit of force.
Hope this helps someone else!
https://www.youtube.com/watch?v=6HvOek1YL1A&t=1s
My NordicTrack E3000 will turn on but the walk belt won't turn. What are potential solutions for this?
If the NordicTrack E 3000 belt won't turn, there are a few things you can check to fix the issue:
- Power source: Make sure the treadmill is plugged in and the power switch is turned on. If the treadmill is not receiving power, the belt will not turn.
- Safety key: Check that the safety key is properly inserted into the console. The treadmill will not operate without the safety key in place.
- Belt tension: Check the tension of the belt by lifting it in the center. The belt should lift about 2-3 inches off the deck. If the belt is too loose or too tight, adjust the tension bolts at the back of the treadmill.
- Lubrication: Check the belt for signs of wear or dryness. If the belt is dry or worn, it may need to be lubricated or replaced. Apply a silicone-based lubricant to the belt if needed.
- Motor: Check the motor for signs of damage or wear. If the motor is not functioning properly, it may need to be repaired or replaced.
- Circuit breaker: Check the circuit breaker on the treadmill. If it has tripped, reset it and try again.
If none of these steps resolve the issue, it may be necessary to contact a professional technician for further assistance.
Nordictrack elite 900 - Does not power on
Sorry to hear that your NordicTrack Elite 900 treadmill stopped working. Here are a few things you can do to troubleshoot the issue:
- Check the power source: Make sure the treadmill is plugged into a working electrical outlet and the power cord is securely connected to the treadmill.
- Check the circuit breaker: Locate the circuit breaker on the treadmill and make sure it hasn't tripped. If it has, reset it and see if the treadmill powers on.
- Check the safety key: If the safety key is not properly inserted or damaged, the treadmill will not power on. Make sure the safety key is securely in place and not damaged.
- Check the fuse: Some treadmills have a fuse on the power supply board or control board. You can check the owner's manual to see if your treadmill has a fuse and where it's located. If the fuse is blown, replace it with a new one of the same rating.
- Check the motor: If the motor is faulty, the treadmill will not power on. You can use a multimeter to test the continuity of the motor. If the motor is not working, you may need to replace it.
- Check the control board: If the control board is not working properly, the treadmill will not power on. You can test the control board with a multimeter to see if it's receiving power and sending signals to other components.
If you're not comfortable troubleshooting these issues on your own, it may be best to contact a professional technician or the manufacturer for assistance.
if u like to tip me
https://paypal.me/AymanZiyat ty
Nordictrack e7.7 incline wont lower.
Based on the symptoms you described, it's possible that your Nordictrack e7.7 elliptical may require a new motor/linear actuator assembly to fix the incline issue. However, before making any replacement, it's recommended to have a professional technician inspect and diagnose the issue to confirm the root cause and ensure the correct replacement.
Hello my nordictrack c2000 will not stay running. When I push the start button the belt moves for a second and then the whole machine resets. How do I fix this?
Here are a few potential solutions to try:
- Check the power source: Make sure the treadmill is properly plugged into a working outlet, and check that the circuit breaker or fuse is not tripped.
- Check the safety key: The safety key is a small plastic key that is inserted into the console to allow the treadmill to operate. Make sure that the key is properly inserted and that the key is not worn or damaged.
- Check the console: Make sure that the console is properly connected to the treadmill, and that the console is not damaged or malfunctioning.
- Check the belt: Make sure that the belt is properly aligned and tensioned. If the belt is loose or out of alignment, it can cause the machine to reset.
- Check the motor: If the above steps do not fix the problem, the motor may be malfunctioning and needs to be repaired or replaced.
- Check the control board: If the above steps do not fix the problem, the control board may be malfunctioning and needs to be repaired or replaced.
Nordictrack elite zi beeps,not working
please keep from standing on your machine once you turn it on and test the buttons to notice if you experience anymore beeping. If not, then the area below the belt might need some oil to lower friction. If so, please check that all covers for any power source or circuitry are put into place properly. Otherwise, you might need to have the
Thank you.
Treadmill won't lock back in upright position
Please check for any broken parts of the treadmill that would lead it to not lock. You can also check for any debris that may be stopping the locking mechanism.
If the previous measures do not work, please reference the trouble shooting section of your manual to help move forward.
Thank you.
