20 Most Recent Cardiozone E-CZ200 Elliptical Crank Shaft Questions & Answers
Use a non alcohol based silicon spray or liquid. The WD40 brand make the 3 in 1 silicone spray and it’s good for all non waxed running belts. Just make sure you get the spray in the middle of the belt. (Underneath of course) watch a YouTube video if unsure.
Cardiozone... | Answered on Jan 03, 2019
Nice blog. Thanks for sharing this valuable information.
<a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Treadmill Dealer in Chandigarh</a>
<a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Treadmill Dealer in Mohali</a>
<a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Treadmill Dealer in Panchkula</a>
<a href="https://sportsindeed.com/excercise-fitness/treadmills.html">Buy Treadmill in Chandigarh</a>
Cardiozone... | Answered on Nov 27, 2018
This could be cused by the the display cover you touch to control the functions pressing on the touch switch array just under it. Carefully remove this. it is held on by adhesive and see if the symptom goes away. If it does, look for any dents on the cover. I have worked with these type of switches for nearly 20 years and they can be problematic. The other possibility is the mechanical switches you use to increase/decrease speed or tilt. They plug in seperately and you can disconnect them to see if they are causing the problem.
Cardiozone... | Answered on Dec 29, 2013
buy it from www. fitnessrepairparts.com
God bless you
Cardiozone... | Answered on Oct 02, 2012
When i turn in my Cardiozone Club Max Hrt. it starts showing SI 2.
Cardiozone... | Answered on Jan 21, 2012
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Cardiozone... | Answered on Sep 13, 2011
Unplug your unit, then remove motor shroud have a good light the sensor is either mounted on the frame by the front roller/pulley unit or it is mount on the motor sometimes by the flywheel sometimes on the opposite end. Next step is to locate the motor control board and plug you uit in. Your board should ligt up with red ,green, or amber L E Ds now manually move the running belt and you should see one of those lights flicker or not if it does then the sensor is working , then we other issues, if not either we have a defective or misalign sensor. An if your unit needs lubrication use a synthetic silcone product.
Cardiozone... | Answered on Mar 13, 2010
The code indicates lack of feedback data from the belt motor. The recommended fix is to re-calibrate. Here are the calibration instructions.
Our treadmill is equipped with a software package that will perform a calibration sequence unique to
your specific model number. Please perform the following steps to calibrate the CARDIOZONE
ELITE TREADMILL.
1. Unplug power cord from outlet strip.
2. Attach Safety Key to console.
3. Plug power cord into outlet strip.
4. Initiate calibration sequence. Locate hole on the back of the console and insert the eraser end of a
pencil through the hole and press the calibration switch twice. As show on page 14.
5. CL21 should appear in the Time window, if not, continue to press the calibration switch until CL21
appears.
Note: During the calibration sequence, the Time window will display which step you are at in the
process (C21, C22, C23 and so on). The CAL/DIST window will display which key should be entered
next. For example, “E” for Enter, “P” for Power, or “SS” for Start / Stop.
6. CL21: MPH or KPH will be flashing in the Speed window, pressing the Speed +/ - button will toggle
options. Choose MPH (KPH), press Enter.
7. CL22: 8, 10, or 12 (13, 16, or 20 in KPH mode) will be displayed in the Speed window, pressing the
Speed +/ - button will toggle options. Choose 10 (or 16 for KPH mode), press Enter.
8. CL23: FFF, UUU, or HHH will be displayed in the Speed window, pressing the Speed +/ - button
will toggle options. Choose UUU, press Enter.
9. CL24: 111 or 222 will be displayed in the Speed window, pressing the Speed +/ - button will toggle
options. Choose 222, press Enter.
10. CL25: AL1 or AL2 will be displayed in the Speed window, pressing the Speed +/ - button will
toggle options. Choose AL2, press Enter.
11. CL26: OPA or OPI will be displayed in the Speed window, pressing the Speed +/ - button will
toggle options. Choose OPA, press Enter.
12. CL27: Blank (nothing), “a”, “b”, “c”, or “d” will be displayed in the Incline window, pressing the
Speed +/ - button will toggle options. Choose Blank, press Enter.
13. CAL/DIST window will display “E”, Press Enter. “55” will display in CAL/DIST window.
14. Press Start/ Stop.
15. At this time, make sure you are not standing on the walking belt, as the machine will automatically
initiate belt movement and run through a complete calibration and diagnostic routine.
Press Enter, belt will begin to move, unit will begin self-calibration.
16. When Speed and Incline calibration has finished, press Power button twice, display should blank,
and treadmill should be ready for use.
To avoid possible damage to the treadmill and the possibility of injury, do not
operate the treadmill until the problem is corrected. Call Keys Technical Service
at (888) 340-0482.
Good Luck! I hope this is very helpful!
Cardiozone... | Answered on Nov 23, 2009
Google (Freespirit)(903)(manual) without parens.
Exercise &... | Answered 2 days ago
No. Mine isn't.
Exercise &... | Answered on Feb 13, 2020
Cardiozone E-CZ200 Elliptical Crank Shaft Logo
0 questions posted
Top Cardiozone Exercise & Fitness Experts
Jesse Garza
Treadmill Repairs...
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Cardiozone Exercise & Fitness
Most Popular Question
cardiozone sports foldaway treadmill
  • Exercise & Fitness
