20 Most Recent Samsung LN-R328W 32 in. HD-Ready LCD Television Questions & Answers
Samsung LNR328w, T-Con Board
What is the part number on the board?
12/30/2017 11:54:45 PM • Samsung LN-R328W... • Answered on Dec 30, 2017
Samsung LA32R71B
first of all what area are you living in in Philippines 220v as there is voltage rating differences in Dubai Djibouti 220v Dominica 230v Dominican Republic 120v Dubai 230v 64 other voltages. 50Hz the board will be set for country of origin, this could mean the power board can be getting more than the ratings need, there will be voltage regulating chips on the power board, main voltage can handed depending on the chip installed up to 600 volts but the other parts cannot handle low voltage or high voltage, this could mean a spike in voltage may not blow but it may weaken the voltage out. i.e capacitors- voltage regulators or even diodes. these have to be checked.
6/26/2017 12:06:30 PM • Samsung LN-R328W... • Answered on Jun 26, 2017
Samsung LN-T3732H 37" LCD
T'Con board fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
5/12/2017 1:23:19 PM • Samsung LN-R328W... • Answered on May 12, 2017
Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
2/5/2016 12:50:23 AM • Samsung LN-R328W... • Answered on Feb 05, 2016
0answers
Green spots on screen of Lcd
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Screen-shots to defective LCD are given. You can compare it to that of your TVs' and can make sure about the fault.
4/20/2014 10:53:01 AM • Samsung LN-R328W... • Answered on Apr 20, 2014
4answers
No picture on samsung lcd tv
I have the same problem. I brought a Samsung 46" in July 07 and on Jan 8, 2008, video went blue.
I called Samsung and sent out technician and they replaced the motherboard.
Two hours later, same problem occured. I called today and Electronic Company thinks I have a bad LCD panel.
11/23/2013 9:48:11 PM • Samsung LN-R328W... • Answered on Nov 23, 2013
My 40" Samsung lcd went to no pic. but the sound
Hi thereIt sounds like your inverter board went bad. check out on the part number and look for it on ebay you will safe some bucks
10/24/2013 4:38:25 PM • Samsung LN-R328W... • Answered on Oct 24, 2013
Samsung lcd with built in freeview, changes the source on its own, remote not working either
Check its panel control switches. Replace the panel control board. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there.
11/30/2012 2:47:48 PM • Samsung LN-R328W... • Answered on Nov 30, 2012
Samsung LN-R328W 32 in. HD-Ready LCD Television Logo
79 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung lcd picture goes black when
  • Televison & Video
