20 Most Recent
Samsung SP42P2S Television Questions & Answers
Where is the bulb located in a Samsung Tantus model SP42W5HP?
If this model even uses one-(check owner manual which will have instructions if it does) it will be behind a door on rear of the unit in most cases--this unit is so flat up front I doubt it is there but could be.GOOGLE is a good place to search based on the model number "manual" or "lamp replacement" etc.
Had to get new DVD player as old one packed up.
to put this simply ive spent almost all day advising on this exact problem have alook at my fixes and it will show you the problem but to put it simple you either have connected the wrong cables ie-- rca vs caroma the best way to fix this is to correct the setting in the output on your dvd player it needs to know what signal to send the tv ie rca caroma or hd cable
best of luck let me know if you need further help
sonic boom electronics
Have a 42
Hello
I have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.I don't have the horizontal line problem but I do get that random black screen issue. I called xbox support and they told me to change the settiong to 1080i (found under console settings/Display), so far I haven't had any issues.
And my problem is also resolved and its working fine.
Assistance by phone seven days a week.
1800 555 741
Thnaks & Regards
Flicking standby
Power supply is developing a problem sustaining voltage regulation and is programmed to shut down. Or it could be a bad OP-Amp on the interface board that's not closing when voltage is applied. Your tv needs servicing. You can send it too us or at your local tv repair shop for proper troubleshooting and repair.
Lines
Have you try'd cleaning the screen, my friend had lines on his, he took the screen out, seperated it (2 pieces) and took his time cleaning it, seem'd 98% better when he finished
Samsung projection tv
Unplug it and plug it in again. This worked for me and I have a very similar problem occasionally. Turning the power off and on with the remote will not work.
Convergence settings
7 8 9 to select R G B, 4 to select moving part a line, full line or the whole matrix. S.mode to save your setting. Adjusting using arrow keys.
SP42W5HFX menu problem
Here is what going on. This is a internal fix. You need to do a small voltage adjustment. There are 2 controls. Your VS adjust and your VA adjust. Maybe your VE adjust. Look inside the panel there will be a sticker with the correct voltage. Just adjust accordingly. Be very careful. These are very important adjustment.
Best regards
Circuitcity
